172 Manifold to Cat join - Help
Car  172 FF and Fabia VRS
Hi All
any tips for undoing the sping loaded bolts?
going in from the engine, seems the one side is rounding off and we cant get a socket to grip.
PITA to do - any other suggestions for undoing the bolts?
tar
Phil
Cut them off and buy a new fitting kit from Renault.
I've had to do this both times I've done the job.
thats a thought i had
Hacksaw? or is there a better tool?
got the new one ready to fit to stop my blowing
I used a friend's Dremel with a small cutting disc to cut the bolt in the middle, where you can see it between the clamp.
If they're scabby, cut them off.
Buzz gun with a 1/4" attachment notmally does the trick.
Also put some copper grease on the new fixings to make life easier if/when you have to undo this joint in future.
Yeah was going to copper grease after
just need to search for my dremel - not seen it since i moved house lol
