chris blue
clio rs 220 trophy
Just got a pair of Corbeau seats. 1 will definitely need a subframe as only comes with side mounts.
The other came with runners (Corbeau Clubsport) , so i thought maybe i could fit without a subframe
Having removed the passenger seat, it looks like if it wasnt for the running gear on the door side, which raises up above the threaded upward pointing bolts, you could fit the mounting plates on the existing runners? Is there any way to extend the bolts pointing upwards, (Then use some spacers to raise height a little) or get specialist bolts that would extend and screw onto the upward facing bolts.
If i discarded that idea, and removed the OEM runners, i then notice that because the exiting runners are staggered, you must have a specialist subframe to fit. Am i right in assuming that? To make it easier anyway.
Then we have the drivers side, and mine only came supplied with mounting side frames (Corbeau Pro-series 1) so assume have to have a subframe, altho may be a little lower than the passenger seat as will not be on runners
Last question- the bolts holding the runners on. The securing bolts of the side nearest the door dont go through the chassis, just the upper part of the subframe, any easy way to remove these bolts- Or just fiddle ?
And the side nearest the handbrake the bolts appear to go though the chassis around about where the exhaust is routed? I think i just grabbed one while feeling under (Non raised) the car. Any tips on this and am i correct. Any PITA areas or shall i just charge ahead
Any tips on fitting the harness, have a rear roll cage fitted.
Thanks in advance
Thanks in advance
