Idle Rattle
  Clio 182
2004 Clio 182
The car has developed a rattle on idle, it happens when the car has reached temperature. At first I thought it was the exhaust heat shield. I discovered yesterday that if I engage the clutch the rattle disappears. Could it be the clutch release bearing? Or a worn mount?
Many thanks.
Ex-User (72296)
  Clio 172
I bought a Valeo clutch kit from GSF/ECP with a discount code for £70 iirc, and then paid a local garage £200-£250 to fit it.
I had the rattle for quite a while before I got it changed as it does no damage etc, just a bit annoying.
  Clio 182
I have two options with ECP at the moment, Transmech £131 or Sachs £152, a 30% off discount code can be added when checking out. Are either of these brands worth checking out?
  Clio 182
Manage to pinpoint the rattle coming from clutch this evening, it's definitely the clutch.
Took the car out for about a 20 minute drive, the rattle has now disappeared but my guess is it will return when it cools down. Does this sound like a typical clutch problem?
I read this earlier,
A bearing noise that occurs when releasing the clutch pedal to engage the clutch while in neutral, but goes away when the pedal is depressed is caused by a bad transmission input shaft bearing.
  172 Cup
Have you experienced clutch judder at all? I endured this when the clutch release bearing in my Cup was on it's last legs.
  172 Cup
  monaco 172
It's not the fork vibrating around the gearbox is It?
Take the cable off the fork and lightly put your finger on it and see if the vibration is still there
  monaco 172
If it is the fork then it's probably just a little looser in its housing than it used to be so is vibrating on the gearbox.
It might not be that but it's worth checking if the rattle goes away when you press the clutch down.
It could be the release bearing rattling while there is no pressure on It, which if it is you will need to take the box off to investigate.
  monaco 172
  Clio 182
I will be checking out the fork first out of those two, is it easy to adjust the fork, tighten it back up?
  monaco 172
Don't think so. It just slots in and sits behind the bearing. Clutch cable been a little slack might cause the fork the resonate a little more.
  Clio 182
So my options are to just put up with the noise or else get the while clutch replaced? The car has recently just hit 80k and there is no evidence of a clutch replacement in those 80k miles.
  monaco 172
If thats where the noise is coming from then yeh. You don't have to change the clutch you can just change the bearing but you'd be daft to have the box off and not do the clutch.
80k is young for a clutch on one of these h
Unless it's been abused
  Clio 182
That's what I was thinking might as well replace the whole clutch when the box is off.
I've owned the car for the past two months, so it hasn't been me abusing it lol
