Want a hands-free set.
  Clio 182
Looking for some hands-free sets where you can actually play music via bluetooth from your phone, similar to Parrot MKi9200, but I don't want to pay £150 for one without finding other alternatives.
What kits do you guys use or do you know of any others?
Many thanks.
Sent from my SM-G930F using Tapatalk
  S4 Avant
I used to have a connects2 box that had an ipod lead, usb and aux in cable that replaced the cd changer. I bought a cheap aux to bluetooth connector and used the usb port to power it. Bluetooth streaming worked perfectly through the aux input and everything looked fully OEM.
  Listerine & Poledo
How OEM do you want?
Because for what you're asking for you're likely to end up with some sort of control box / panel somewhere on your dash. It's all good for wanting to "retain the OEM look" but the stock unit is pretty poor.
Some options
Adapter to OEM unit - £100
Add-on handsfree - £90 (requires SOT lead)
Headunit - £90 (would require a patch lead to retain stalk controls)
Of course there are hundreds of different ways of doing what you're looking for, these are just 3 at the cheaper-end of things
R3k1355
Also despite it running on the original headunit you won't get song names or any info on the LCD display
  Listerine & Poledo
Very true.
Although swapping out the head unit at all, you'll need to be choosy over parts and cables to retain that dash-top display saying anything other than time/temp and RENAULT
R3k1355
I couldn't find a way to get it working with anything on my 182 to be honest.
Think I found one patch cable that maybe linked into the LCD unit, but then wasn't able to find a headunit that actually outputs anything to show on the screen???
Also I think you need to take the dash apart to access the LCD wiring?
In the end I gave up caring, having the steering wheel controls work was good enough.
  Clio 182
Thats another thing.. i dont want to get rid off cd changer [emoji16]
  Clio 182
Some options
I dont mind having a little lcd screen somewhere on dash, ill look in to the first two options.
  Clio 182
Been looking and seen parrot mki9100. Its a bit cheaper and older but i seem to like the simple and small screen, as long as it shows song name and whos calling im happy.
My mate had a Motorola tk30 in his which i liked but cannot find one for sale anywhere..
  Listerine & Poledo
In the 172 I had to get a £70 cable from Alpine, and it only worked with £200+ head units at the time. It was a nice-to-have but didn't take much effort to wire in, it all just fitted in-line with existing cables.
R3k1355
The headunit itself was compatible with Renaults LCD system or do some have a generic visual output part that can be used across a range of cars?
  Listerine & Poledo
It'll be a listed feature on the headunit "remote display compatible" or similar.
Then you need the clio-specific adapter lead to carry that data to the display. It didn't need "programming" or anything.
For alpine the keyword is "OEM Sub-display Ready". Then a long debate with Alpine Europe to get the right cables
