Buying my son a gaming PC, help.
  BMW M4; S1000 RR
Build critique:
I think you could build something less GPU limited than that for the money. I'd sack off a HDD, 120GB SSD is a bit small these days, 250GB is about £100. Probably less.
That CPU cooler is lame, the PSU looks weak but then hardware is more efficient these days so maybe it's enough.
If you're building yourself (surely that'd be a great father/son thing to do? especially if you've never done it before) then:
Pick graphics card first, I'm just throwing figures out there, but I'd say if you have £1200 to spend on a machine then try and spend £500 of that on a GPU. Maybe even 600.
I'd rather have a s**t looking case and previous gen mobo/CPU and graphics on high/ultra than a CPU I don't utilise and graphics on medium.
Mr R.
  A special one.
Did you reverse over the family dog or something?
FLOL. No mate, im just trying to get an idea on price and spec.
I could do with Billy's current PC to replace my 10 year old HP desk top, so Billy's new PC would be an early Christmas present, maybe.
Daz...
  Inferno 182 Cup
What monitor did you get him in the end? It’s 1080p isn’t it?
Daz...
  Inferno 182 Cup
Nice, I’d get a 1070 minimum for a graphics card tbh.
That’s what I run with a similar monitor and it flys along in every game I’ve tried.
I’ll have a proper look later and do a list if no one else has. You definitely get more for your money building it yourself.
  MK4 Anni & MK5 Edt30
With a £1200 budget I'd be spec'ing a 1070/1070Ti. Don't pay £90 for Windows 10, you can get it on eBay for like £5.
Reduce the ram to 8GB for the time being. He'll be fine with 8GB @ 1080p. Some games with utilise more in the near future and you can just chuck another 8GB in then. Stick a bigger SSD in definitely.
Mr R.
  A special one.
Thanks buddy, building it with Billy will be nice.
When he was 9 we bought him a laptop, I came home from work and Billy had decided to take it apart and couldn't get it back together. Bloody kid's. Lol
Daz...
  Inferno 182 Cup
That’s an example of what you can get for your money.
I would get a copy of Custom PC and having a look at what they recommend for different price ranges. Obviously nothing is definitive, but it’s a good guide on what’s worth buying. If you can’t find the magazine then drop me a pm.
Mr R.
  A special one.
Many thanks for your time mate, is the one you've spec alot better than the one I posted for around the same money?
Daz...
  Inferno 182 Cup
It’s got a better graphics card, cpu cooler and power supply. There’s also more than double the storage space.
Like I said, you can still look through and change some bits for cheaper if needed.
I also haven’t put a copy of Windows 10 on the list.
Daz...
  Inferno 182 Cup
Just noticed the motherboard hasn’t got WiFi built in so that’s something to consider. I’ll blame the football, I was half watching it whilst doing the list ?
  Ph2 172, 106 Rallye
Good list that is mate, pretty much spot on. All I would change is to reduce the RAM to 8GB and use the savings on a better case imo personally. Other than that though this is where you want to be looking op
16gb is about the minimum you want these days. That said, it's always easy to add more at a later date. I'll knock one together on pcpartpicker at lunch.
https://uk.pcpartpicker.com/list/XmnMTB
CPUView attachment 1378682
Intel - Core i5-8600K 3.6GHz 6-Core Processor
CPU CoolerView attachment 1378683
Noctua - NH-D15 82.5 CFM CPU Cooler
MotherboardView attachment 1378684
MSI - Z370-A PRO ATX LGA1151 Motherboard
MemoryView attachment 1378685
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
StorageView attachment 1378686
Western Digital - Blue 500GB M.2-2280 Solid State Drive
Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video CardView attachment 1378688
MSI - GeForce GTX 1070 Ti 8GB DUKE Video Card
CaseView attachment 1378689
Fractal Design - Focus G (Black) ATX Mid Tower Case
Power SupplyView attachment 1378690
Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply
This machine would demolish anything you throw at it. £1100 all in. Could save £50-60 by purchasing a non-K CPU as I doubt he will be overclocking the system.
Bargain that
  Ph2 172, 106 Rallye
I regrettably changed my NH-D15 Noctua cooler for a H115i Corsair All-in-one watercooler. Takes up 4x the space and my temperatures under load went up by 4-7 degrees. Don't be fooled by the D15 being an air cooler, research shows they are beasts.
500GB M2 SSD As the boot drive (m2 plugs directly into the board and is generally a little faster than SATA and takes up less space/no cables) and for storing the games he plays most, the 1TB Platter drive for long term storage/movies/music etc.
  BMW M4; S1000 RR
It's not that the Noctua is a beast (it should be given the size). Corsair stuff is just guff.
  Ph2 172, 106 Rallye
I had a full corsair build previous to my current build and it was flawless. I just think AIO's are shite. I had a custom twin loop system about 6 years ago, whilst temps were great it wasn't worth the effort it took to maintain it. I also had a dodgy fitting and it ended up leaking over my GTX 680's.
I'll end up buying another D15 eventually but this Corsair will see me through the winter as ambient temps aren't going to be too bad (I've a 5930k @ 4.7ghz, was 4.9ghz on the d15, it's like an oven.)
  BMW M4; S1000 RR
Some AIOs are actually quite good. Yes it's anecdotal but everything Corsair I've ever had has broken apart from the case. Infact that's not even true the HDD tray handle snapped way too easily.
H100i developed a bad pump rattle within a year (within warranty, they gave me a replacement eventually AFTER I sent them the faulty one)
SP2500 speakers popped after 2 years (no warranty, they said f**k off)
One out of 2 sticks of RAM became bad after 3 or 4 years (didn't bother pursuing)
PSU died after 5 years (didn't bother pursuing)
Like I said. I know it's anecdotal but that is every piece of Corsair hardware (minus some laptop memory and a USB stick). Dog s**t build quality.
  Ph2 172, 106 Rallye
@Phase1sr If you want a hand to build it, hit me up and I can talk you through it. I would say to ship it to me and I'd throw it together but postage to N.Ireland is usually two-fortunes.
Mr R.
  A special one.
Thanks for all of the replays gent's, I'll read them all later with Billy once I'm home. ?
Greeny.
  440i + 182
Its the best dad ever again.
As above, a 1070 will be good for a few years and perfect for a 1080p monitor, 16GB RAM really should be standard on any gaming PC these days, 8GB doesn't cut it anymore, especially when running Windows, using this will cause regular paging to disk so is best avoided imo.
  Listerine & Poledo
Relevant video content:
  Listerine & Poledo
16GB isn't even enough if you use Chrome and like to leave it open whilst playing games.
There's a cheaper solution to the problem than chucking 64GB of 3200 memory at the problem though.
I appreciate that CS Ballers would rather chuck another £200 into their motherboard than go through the arduous torment of closing a browser they wont be looking at for an hour, but the majority of sensible PC users who aren't using CAD, Adobe and such, 16gb is fine.
I don't know the boy in question here, but I'd say for the price point we're talking about here, an upper-level GPU with 16gb of fast RAM is going to cope fine, especially if the C: is an NVME.
I'm still rocking 8GB of RAM and I game @ 3440x1440. Never had a single issue in any game so far. I guess it's worth sticking another 8GB in soon though, it's pretty cheap these days I guess. Although my PC is literally just a gaming PC, so there's no rush.
  BMW M4; S1000 RR
^ Yup I imagine 8GB is enough if you just boot Windows and then open Steam. Though back in my Eve Online days I could use 8GB running multiple clients but you could easily argue that's not a game... Didn't think RAM contributed to resolution? VRAM yes, RAM ?
Right now I have about my typical amount of Chrome tabs open and my PC is using 5.5GB. I actually experienced memory errors on FarCry5 recently when Chrome was running in the background.
Greeny.
  440i + 182
I upgraded to 16GB when GTA5 came out as was paging out a fair amount, very game dependant though but with Windows 10's bloatware it makes sense if you're building a new machine to put 16GB in it, why would you compromise on a new build? Fair enough if you have an older machine with 8GB DDR3 or whatever and don't want to waste your cash on old tech but for a new build its a no brainer.
Daz...
  Inferno 182 Cup
I remember trying to start up Forza when it first appeared on Windows 10. I had 8gb of RAM and it wouldn’t let me open the game, I had to set up a decent sized page file on the HDD to get it to run.
