Engine wiring loom removal
Have taken the engine out of the Clio today to swap it for another one, I have to swap the lions over to. I have everything off but the loom runs between to main block and the inlet manifold. Is there any easy way to remove this or will I have to take the manifold and injectors out to get the loom out ?.
Dr HMS Derv Destroyer
  MK1DCi/vivaro/REN’11
The big block part at the front of the engine comes off to gain access to the fuel rail and injectors , held on wiTh 2 13mm nuts inside the holes on the from , if I remember rightly
Should look like this with the guard off , loom on show on the rail
  dan's cast offs.
10mm nuts, you may need a 3/8" narrow deep socket to get them.
once it's out of the wiy wiring is a doddle to get off.
