Engine wiring loom removal
Have taken the engine out of the Clio today to swap it for another one, I have to swap the lions over to. I have everything off but the loom runs between to main block and the inlet manifold. Is there any easy way to remove this or will I have to take the manifold and injectors out to get the loom out ?.
The big block part at the front of the engine comes off to gain access to the fuel rail and injectors , held on wiTh 2 13mm nuts inside the holes on the from , if I remember rightly
Should look like this with the guard off , loom on show on the rail
10mm nuts, you may need a 3/8" narrow deep socket to get them.
once it's out of the wiy wiring is a doddle to get off.
