Clio mk2 Volvo 940
Are ride / handling even a slightest consideration in your plans, or is it purely just look?
it can be bouncy and stiff
Dont wanna have to change springsCheapest possible way will be to cut your springs to the desired length
It can be, but not ridiculously much. I have driven some bouncy slammed carsThats not the normal definition of handling, it's pretty much the opposite.
It can be, but not ridiculously much. I have driven some bouncy slammed cars![]()
Dont wanna have to change springs![]()
Pour concrete into the boot until the back is of the right height for you.Dont wanna have to change springs![]()
Me too, the phrase "bloody horrible" was used.
I was following a slammed Polo down the motorway just before Xmas, he hit a fairly insignificant dip in the road and the car shot halfway into the next lane.
Can't understand it myself.
You've gotta change the suspension if you want the look?
If you want it to have stance you have to drop it a load, and have stretched tyres etc. Otherwise it's just a lowered car.
Then you need a full set of adjustable coilover suspension, new wishbones and all sorts.Im not gonna do a crazy stance build, but maybe something like this
No i wanna change to coilovers, not cut the springs and having to change springs Every inspectionSo, wait a minute, you want to lower and stance your car without having to change the springs? Oooookkkkkk thennnnn.
So you want a car with syling features which make it unsafe to drive, and thus unable to pass inspection in your country, but also want it to pass inspection?
The example you posted has clearly had the arch lips flared heavily to accomodate even the undersized tyres on relatively small rims and even then excessive camber is required just to make them "fit".
Please just dont.
Go for 14" wheels and chop the springs. Clio's look s**t on big wheels.
Find some rokkor (can’t remember the other name) coilovers for £100ish and some spacers. Job jobbed
My old car on Rokkor coilovers and cup turinis
View attachment 1402015View attachment 1402016
Was thinking about some 15-16 inch, deep wheels
Even the cheapo coilovers seem to be £250 now?
Probs need to roll/flare the arches as well to get fitment.
I want coils, was taklking about not waiting cut springs. If i cant drive it i will just adjust the height![]()
Stretch tyres purely shout "I'm a tightwad pikey who didn't want to stump up the extra fiver for tyres that actually fit, a man needs his vape juice"
Nor was I...
Point is 195/50 15 fits with a 40mm drop and leaves the car looking good. You wont get wheels and tyres much smaller overall, so going lower starts to require narrower tyres stretched on and excessive camber and body mods to get them inside the rear arch lip, which leaves the tyres poorly supported, bent out of their as designed shape and running on one corner which gives excessive wear and poor grip.
The 'correct' way to stance the rear of a clio would be to tub the boot floor and allow proper suspension geometry with a low ride height, but you will struggle to get the front to work properly.
All bar a very very few of these cars are total abomnations when you consider what a car is actually for.
EFA.Used to daily my drift car without stereo and interior. It doesn’t need to a luxurious ride. I just wanna go low and not be able to get over speed bumps ?
EFA.
No i wanna change to coilovers, not cut the springs and having to change springs Every inspection![]()
That make no sense, you want stance etc, but don't want to change the springs & don't want it that low.Maybe not that low. I just wanted pics to see if 15 or 16 inch wheels looked better ??
So not stanced then ?
Just wanna know what wheels looks best ??![]()
