Corbeau Clubsport?
Where are you pluging your seat belt to? What are you using on the other side and how is been mounted?
All the factory mounts. Nothing's been modified at all.
Just take the lower mount out, feed the belt off the loop, feed the belt through the seat then back onto the loop. Then bolt the fixing back into the sill.
I've even used the factory buckle, just drilled a 10mm hole in the Sparco subframe and fed a hi-ten M8 bolt and nylock nut on the end.
Looks completely factory.
Worth updating this thread now that they're in the car. I love them. For the money, they're unbeatable.
I love the interior now.
The finished interior:
I found them really comfortable and I've got back issues. Sat in them for over 4 hours going down to Blyton one year without an issue.
Dunno like, the car I was in had the sidemounts bolted to proper seat bars. You could feel the base flexing even on the road.
I wouldn't run them personally
Thread bump.
People who have got the XL's. What side mounts your using? Straight ones or ones that are slightly angled?
I believe you'll need the straight 90° ones mate.
The angled ones take up more width.
I thought that as well. I'll be buying some low Jon Foz mounts if that makes any difference. Not sure how wide they go to?
