RecliningClive
Looking good mate, those lights came up mint!
Cheers dude. Yeah they're so much better that the cruddy standard one. For the cruise control you have to sand them out a bit to fit the 182 squib connector. This one was listed as spares of repairs as the leather has pealed but it's perfectly passable. Ordered a machined washer for it yesterday so it's not some piece of crap I'd drilled out myself. Will probably do the wiring soon. Hoping to get some videos together next week.Awesome mate! I now have a 197 steering wheel for my dCi and bought another one with cruise controls for my 172. They feel so much better in the hands!
Loving how your dCi is looking now mate, looking forward to the videos!![]()
I have, get an idea in my head and have to do it immediately! New video today hopefully.Holy crap! You've been busy haha, can't wait for the vids now![]()
Cheers D. Yours is going together properly! Mine is chucking a load of smelly and dirty used parts on so is a bit easier ?Top work Graham, jeez you crank stuff together fast !!
Cheers dude, wiring is very satisfying to do properly!Epic work, it's nice when someone does the job proper and doesn't bodge it!
????? You're not the first person to say that! I get my haircut marginally before him ?
Yeah I broke it for spares which in hindsight was a stupid thing to do. I should have just got a new engine in it. Up close that car was immaculate and this one never will be. This one needs a new fuel system and the turbo is leaking. I have a vague idea for more power but it's probably a pipe dream.Love it and the fact your doing it all properly. What happened to your old one did it end up getting broken for parts or did you manage to sell it as a hole car as was needing an engine if I remember correctly?
Ah! As far as I know, and I've tried, you can't reprogram the UCH to not have ABS. The clocks flag the light based on what the UCH is looking for. In my cup I have an ESP light on because it has a 182 ECU kit on, very annoying because I have to explain the car never had ESP to the tester. a 172 cup ecu set might sort you out.Coming along great?
I need to reconfig the clocks on my kangoo to lose the esp on the 2nd hand ecu/uch i have. Looks pretty simple according to the manual, any tips ? Says batt off, reconfig without turning ign on etc. Do you need to manually input vin on clip ?
Need a video of what it sounds like with a decat[emoji6]
Also get rid of the backbox for some pipe[emoji23]
Thank you! It's not exactly the fastest car but now so much better than it was!I was reading through this last night. I really enjoyed the read & seeing the progress. Nice work! ?
Mental indeed, should probably check myself in somewhere.All this effort! Mental!
Totally agree with @Mazz they sound the same with a little extra spool whistle. A flute nails it!Need a video of what it sounds like with a decat![]()
Also get rid of the backbox for some pipe![]()
Managed it with a couple of hours on clip playing about ?
Basically recalibrate the multiplex network to set abs and steering angle sensor to missing
Then recalibrate the clocks to remove course (Trajectory) control system to turn the esp light off. Job done no more network faults or serv light. Not sure if abs light is on as mine does not work/cup clocks etc - still serv light not on so assume off.
You absolute legend. Just re-programmed the Cup clocks to not look for ESP (not sure why they were programmed to look anyway) and it worked a charm. Legend!
Pretty sure it's in the airbag ECU. Wiring wouldn't make a difference because it's just looking for different modules. From my experience if the VINs don't match it nabs it from the airbag.Good to hear its sorted - nothing worse than unwanted lights on ! i knew it wouldnt be custom firmware for cup uch.
Do you know where the vin is stored ? my old ecu/uch pack said d4f instead of f4r and vin number of pretty much 12345. Fitted 2nd hand setup and still says the same ? is it the clocks or is it due to incorrect wiring ? wiring is chopped about i dont think its 172 loom however its all working correctly for first time in my ownership.
Thanks matey, why is your ABS a mess :S sensors and rings is all you need (if you even need those!)Total legend dude, nice work !
Hopefully I can get mine done soon and I'm sure you'll volunteer to have a look at my abs mess lol
God knows. I get an idea in my head and do it straight away at great expense to any spare time at the weekends! All the sport parts are brilliant for an every day road car. This is now just a car they should have created from the factory. That wouldn't have been a bad idea to use a 172/182 loom but it would have been similar if not more work as the DCi has EPAS and different clocks. Knowing I started with a working dci loom seemed the right thing to do but there are only a few select differences between that and a sport one. Anything is compatible with changes! The pin out are exactly the same.How the actual f**k have you managed to get that done in two sessions!!
The way you were talking about the wiring of that car was scary! You clearly know these things very well and judging by your dash removal, it’s obvious you removed several before!
Completely admire this, as I started watching this build I’ve been thinking “what on Earth is the point”...but then when I (and many others) took literally everything out of the car to loose weight fom the car, people think the same thing as the RS Clio is very capable in standard form...
I thought you were going to swap from poverty spec loom to a 172 complete loom, why is this not the route you Took? I’m guessing it’s not compatible but either way...with my very minimal knowledge of wiring there’s no way I’d have tackled this!
You brave man!
And it works!!!
I sure did. However the only reason it gave me cruise is because I could swap back to the correct ecu. The gear ratios in the jb3 were all wrong for the cruise in the 80 ecu to work. Cruise is in the ecu and simply needs enabling and the wiring running. It’s actually the best cruise control system I’ve used. Keeps the speed really well.Did you program the new uch with a clone clip ? I fancy cruise on my dci - would a n3 uch work on the pov spec loom as mine is n1 from memory.
First time i have read theough this Graham, and its a fantastic one to read! Brilliant work and you clearly have a great skill, and know what you are doing! These Dci’s really are cool little cars!
Thanks Austinthis is my second dci rep now so it was a no brainer from me as soon as I lay hands on it, especially as most of the parts were free. It needs heart surgery though as it's got quite a few issues with the fuel system, it's running very lumpy, smokes too much and a turbo blowing oil through the seals. I'll probably do it all and the donor are waiting but the time and money just isn't. Time will tell. I need to read about your rare beast!
Ciao, I’ll PM you.Hi there, I'm a new member of the forum. I've read all the thread and is just impressive! I'm experiencing a little issue with the ABS light on my car as I'm just finishing the swapping of the rear brake system (it's a Clio 2 1.5dci 65hp). My car originally had the drum brakes on the rear with magnetic ABS rings, so I also changed my ABS control unit with one I took from a 100hp Clio 2 (without ESP). The problem is I took the calipers with the ESP sensors on the rear from another Clio 100hp (ref. number 6000073528/7). I would like to ask if I have to change them with the ones for ABS system only (ref. number 8200186298/9) so the abs warning goes away?Sorry for my bad english, I'm from Italy ?
