Clio 182 Brake Master Cylinder part number?
  Clio
Hi,
I have had a look but not been able to confirm the OEM Part No. for the brake master cylinder on a Clio 182. Does anyone know what this is and what a reputable supplier for it would be?
Regards,
MarcB
  182 Trophy & 197 F1
I beg to differ as there is 3 listed for the car.
I know for a fact that the Clio 182 Trophy has the following. -
Make - TEVES
Pt No - 7701207754
RRP - £136.18+vat
The 3 choices for the Clio 182 are as listed from the genuine renault parts catalog
  Clio
Hi all,
I think I have identified the MC with it still being on the car. It has a round end to it and looks like the one in the attached image (stolen from somewhere on the internet).
Does anyone know what brand this one is?
Is the issue between different brand Master Cylinders down to differently positioned brake pipe connections?
Thanks,
MarcB
  182 Trophy & 197 F1
The one above looks like a ATE one but could be totally wrong.
The logos look the same.
  Clio
Hi,
Great thanks so hopefully the one linked in your email post should be the same spec?
For my own learning, what is the difference between the three brands of Master Cylinder used? Are the connection points spaced differently or do they have different threads?
What is the experience of SpareTo for parts supply as well?
Thanks!
MarcB
  182 Trophy & 197 F1
Make - TEVES
Pt No - 7701207754
RRP - £136.18+vat
@DickP
Look at the part number above - 7701207754
Just put it into Ebay and a new one comes up but it has the ATE marking on it.
leeds2592
  Bean 182 + E70 X5
Yeah seems they dont care about the RHD market anymore🙄
Typical.
You don't know where I can get all the seals for a master cylinder do you? I'm gonna take a punt off a used one on ebay but want some seals incase it's knackered.
botfch
  Clio 182
Typical.
I think I've got one somewhere that was working fine when it came out the car if you want that ?
leeds2592
  Bean 182 + E70 X5
Yes please, that'd be great. Is it an ATE one? Any chance you can send me a photo just to confirm its 100% the right one? If it is, just let me know how much you want.
botfch
  Clio 182
I'll check what it is tonight and get some photos.
leeds2592
  Bean 182 + E70 X5
The seal kits are all the same for the MC but obviously one is for LHD and has ports on one side rather than the other
This is only one that comes up.
What's the different between the Bosch/ATE units then? Purely just the manufacturer, everything else the same?
Ta mate
Speedo Gonzales
I doubt there's anything different tbh mate. The bore are 20.6mm across the sport and like 19.1 for non-sport iirc
Get a spare MC to take apart and match the seals, see if there are any differences
The stock image on that looks like the same seal kit I got for the ATE one. I bet if you dig far enough you'll find Bosch and ATE are in the same group of companies
leeds2592
  Bean 182 + E70 X5
Yeh mate, that's the plan.
Hopefully if the guy above's is the right one and works. If not, I'll take one apart and get the seals replaced. Pretty sure that's my issue now after messing about with it the other night.
Louis
I Love Ed Sheeran
Input the ATE part number for LHD master cylinders and just type repair kit after in Google. They must exist
leeds2592
  Bean 182 + E70 X5
Yeah best to get them replaced anyway. I need to get my 197 MC sorted, no motivation though
Right, master cylinder arrived today (thanks again @Archtronics!)
I know how to remove and what not, but when refitting, is it just a case of refilling reservoir with fluid and bleeding as normal?
I've got an RS Tuner to bleed the ABS if needed.
Speedo Gonzales
Bleed it with the RS Tuner a few times first without cracking the bleed nipples
Then bleed with the RS Tuner
For the love of god don't go heaving on the pedal 😂 😂
leeds2592
  Bean 182 + E70 X5
Without cracking the bleed nipples? So just activate the abs with the rs tuner?
Already said to @Louis that when bleeding I'm gonna just use a vizibleed to be mega careful and not smash the pedal right to the bottom!
Speedo Gonzales
Yeah it will prime it and get any air pushed to one spot mate
I've use the Eezibleed on mine a few times tbf, you just need enough pressure to make it dribble out. Fingers crossed yours will be ready for CSF 2022 ;)
leeds2592
  Bean 182 + E70 X5
Saweeet.
Woahhh, 2022? Lets not get ahead of ourselves here!!!
ripp
  182 FFAT
I thought the 182 (or at least the cup/trophy) had a bigger piston diameter? 22,8 maybe?
