Fuel line clio to fuel rail
  BG Clio 182
Another thread revival!
Hi all, had an issue over the weekend...
I seem to have caught the fuel rail on the cambelt and it's rubbed away on it so now it's spraying all over the engine bay so I clearly need a new pipe.
Thanks to sbanc above for posting his own part but he's overseas so it'll cost a bomb to ship!
Does anyone know where I can source one of these from? I've tried messaging people on eBay with no reply on breaking cars but id prefer a new one anyway.
Quite a few on eBay for 1.2s but I'm assuming they don't fit?
If anyone knows anywhere I can buy the fuel line from it'd be appreciated!
Thanks
Alex
  182 clio
Thanks
Alex
Not sure if you can still get them new?
Try renault and find out part number
  BG Clio 182
So Ive made progress and here is what I'm after
This is the diagram sent across from a supplier
Can someone let me know if it's number 8 I'm after as for some reason it looks like number 12 is also a connector??
Thanks!
Coops Mk1
  Lots of Scrap...
  BG Clio 182
Thanks but the rail itself has worn away and needs replacing!
Coops Mk1
  Lots of Scrap...
ah sorry thought just connector you needed as that was circled, I should of read the thread properly!
  BG Clio 182
SOLVED
part arrived and it was the right one.
Fit great and even has a bit of a braided coating over the part that goes over the cambelt.
I have put a little cable tie on the top to stop it happening again. I doubt the heat will melt that and I won't need to do this again.
Underneath chasing that connector over was a right pain, it the push tabs didn't help too much. Some proper Welly is needed and I didn't feel comfortable doing it as I was concerned id mess up the rubber seals inside but all seems good now.
Only did a quick jaunt up and down the road but 3 miles in and no more petrol stench or the pipe touching the cambelt.
I will add though that no replacement clips that run along the chassis leg were provided. Need to reuse the old ones.
  Clio
Hi I have a 2004 Clio mk2 1.216v car cranks but won't start have checked spark and fuel air
Had green flag out and they could get it started . Can anyone help
  172 Ph1
SOLVED
How much did the pipe cost ?
As I took it soon myself to come up with an alternative fix on mine .
I make these .
  172 Ph1
Been working on a full length version of the fuel line , testing it begins this week . See how it goes .
