This just fell off my 182? Any ideas?
  Z4x2 & buying a 182
  Z4x2 & buying a 182
I'd say it was off a pulley.
hmm, Ok should I be worried about driving it? Drove fine afterwards for a couple of miles? Getting booked in to a renault specialist but they are an hour away now I am worried I should be getting it towed there?
If you are unsure where it came from, I would advise not to drive it, as if from the aux pulley the aux belt could come off and take out the cam belt
  Z4x2 & buying a 182
since I bought the car a couple of weeks ago the steering has been heavy. also doesnt start straight away. No idea about water pump.
Now just have to work out how to get it to the garage?
Archtronics
  Clio 182
Just get it recovered to the garage, AA and the like have options for home cover or get someone with a trailer/van.
  Z4x2 & buying a 182
yeah Ive got RAC
hoping this doesnt become expensive but was expecting it to fall apart relatively quickly.
R3k1355
Does it have to go to a specialist?
If it's just a problem with the idler any half decent garage should be able to replace it?
  Z4x2 & buying a 182
Yeah could do....got a fair amount of other stuff I want looking into and a general once over so was going to get it over to two techs in dartford at somepoint anyway
  Z4x2 & buying a 182
there were some slightly funny noises in the run up to it coming off, then hit a bump and it came off. car then drove fine. Havent been able to get underneath but had my fingers crossed it was an exhaust related piece but cant see how it would be.
  Z4x2 & buying a 182
could it be gearbox related? Thinking about it, it had just jumped out of first into neutral after some over eager driving? (still getting to know the car).
1985michael182
I think these guys are right. If you look at your very 1st post of the 3 pictures.
The 3rd picture where you stood the item up you can clearly see most of the outer surface is worn except that top edge like 4mm of it is still untouched
  Z4x2 & buying a 182
cheers guys thanks for the help :)
I guess this is a good introduction into frenchcar ownership!!!
