Snow foam without a hose or pressure washer!
Car  Clio182
Ok - so I’ll apologise immediately for such a weird post! And explain why....
I’ve just moved into a flat and have no outdoor tap or electric supply. I can get round the power issue with a Ring battery pack which has a built-in inverter. Very handy piece of kit to have. But the water issue is tricky!
Does anyone else have a similar problem? Is there a non-hose solution?
But it would empty that bucket very quickly surely?
not as fast as you think, I've done it a few times. Yes you have to keep it topped up but you can get the job done fine. Pressure washers use quite significantly less water than if you were to have a hose running. Increased pressure doesn't necessarily equate to increased volume
There’s this on amazon same price as a pressure washer tho 🙈
pressure washers don't require a water supply with any pressure. You can run them from a bucket if need be.
I use a 25 litre fermenting bin. The only time I use mains water is to rinse off the car.
snow foamers are a pain, get some Reset in a nice warm bucket :)
I bought a 25 litre water bottle from a caravan shop and a connecting hose from Karcher...
