Snow foam without a hose or pressure washer!
  Clio182
Ok - so I’ll apologise immediately for such a weird post! And explain why....
I’ve just moved into a flat and have no outdoor tap or electric supply. I can get round the power issue with a Ring battery pack which has a built-in inverter. Very handy piece of kit to have. But the water issue is tricky!
Does anyone else have a similar problem? Is there a non-hose solution?
  Clio182
GrahamS
pressure washers don't require a water supply with any pressure. You can run them from a bucket if need be.
GrahamS
But it would empty that bucket very quickly surely?
not as fast as you think, I've done it a few times. Yes you have to keep it topped up but you can get the job done fine. Pressure washers use quite significantly less water than if you were to have a hose running. Increased pressure doesn't necessarily equate to increased volume
  Clio 172 Cup
There’s this on amazon same price as a pressure washer tho 🙈
MRBILLYUK
  FF Jeden Osiem Dwa
I use a 25 litre fermenting bin. The only time I use mains water is to rinse off the car.
rs 1an
South East - Essex
snow foamers are a pain, get some Reset in a nice warm bucket :)
  Clio Sport
I bought a 25 litre water bottle from a caravan shop and a connecting hose from Karcher...
