Snow foam only works on one car?
Short Norman
  997 C4S
Right just washed our cars and used the snow foam, but for some reason it only worked properly on one of the three cars.
On the other two it loosened the dirt but didn’t allow it to be removed with the pressure washer.
any ideas why it would work on one but not on another.
Short Norman
  997 C4S
Did they have protection on?
The one it works on was machine polished of some sort before we bought it (never been polished/waxed while we’ve had it), this car is also kept in a garage.
the other two have both been polished by us with autoglym SRP and are kept outside. Both these cars are white althought I don’t really think that makes a difference 😂
leeds2592
  Bean 182 + E70 X5
I’ve never used a snow foam which actually cleans the car at all
This.
I've tried a couple and never really got on with them unless the car was really well sealed with something.
I started using it in a pressure sprayer instead of through the lance, seems to work so much better.
imprezaworks
  Mk5 Golf GTI :)
Is snow foam really for a cool look factor. Was always under the impression they didn't do much.
Nothing a blast with a pressure washer before hand wouldn't do.
  172
The only real reason would be protection on the car that you feel it worked on.
Personally I'll only use snowfoam/prewash if a car is heavily soiled, it doesn't take loads of dirt off but it certainly softens it up.
This was Avalanche (AF) on my F31, just left to dwell for 5 minutes then blasted off. Not clean by any mean but it did take a lot of dirt off making it a safer wash.
Mr Trailer Man
Avalanche has a small amount of their citrus prewash in.
Works well.
  Clio 182
Breaks down the dirt and less likely to create swirl marks etc like pressure washing. That said, it's not the best if you're only snowfoaming it and not hand washing afterwards.
davo172
  TCR'd 172
Bilthamber autofoam is probably the best for actual cleaning power
This ^^^ or candy fluff avalanche is shite on my experience citrus power on the other hand is very good neat or added to foam.
