Doesn't like turning over after stalling
So the garage where the car is stored is on a hill and there's a tight turn to get out which means a 3 pointer every time
But when on full lock and no throttle then the car cuts out - been told this is cos of hydraulic PAS, can anyone clarify this?
So the car is essentially stalled even with my foot on the clutch due to full lock, I turn the key over and it has to try harder to start again and most of the time I have to blip the throttle to convince it to start & hold revs
Lemme know what you think, all help is appreciated
Car is a 2000 Renault Clio 172 Ph1
  2003 Clio 172
There is a wee pressure sensor in the PAS line at the front of the engine and from what I recall, it is supposed to raise the idle/revs when it senses loading on the steering pump........perhaps it isn't working? They do leak too so maybe worth an eyeball?
Pressure sensor near the alternator on the hydraulic line. If you need a sensor I have a few working ones
All it does is increase the RPM of the engine on full lock so it doesn't stall out
Sounds like you've cracked it to me, will have a nosey on the weekend maybe & get back to you on that @YorkshireKyle thankyou!
