Doesn't like turning over after stalling
So the garage where the car is stored is on a hill and there's a tight turn to get out which means a 3 pointer every time
But when on full lock and no throttle then the car cuts out - been told this is cos of hydraulic PAS, can anyone clarify this?
So the car is essentially stalled even with my foot on the clutch due to full lock, I turn the key over and it has to try harder to start again and most of the time I have to blip the throttle to convince it to start & hold revs
Lemme know what you think, all help is appreciated
Car is a 2000 Renault Clio 172 Ph1
  2003 Clio 172
There is a wee pressure sensor in the PAS line at the front of the engine and from what I recall, it is supposed to raise the idle/revs when it senses loading on the steering pump........perhaps it isn't working? They do leak too so maybe worth an eyeball?
I Changed My Name
Pressure sensor near the alternator on the hydraulic line. If you need a sensor I have a few working ones
All it does is increase the RPM of the engine on full lock so it doesn't stall out
Sounds like you've cracked it to me, will have a nosey on the weekend maybe & get back to you on that @YorkshireKyle thankyou!
