F7P - F7R any visible differences?
  Clio Mk1 1.8 16v
I've just picked up another Ph1 16v and the seller said the engine has been swapped. Suggesting though that it was swapped to a F7R.
Are there any physical differences visible from the outside of the engine to tell the F7P and F7R apart?
Jaff.
the stamp on the block by the gearbox housing at the front will tell you.
take your phone and take a picture
  Clio Mk1 1.8 16v
When I get up there to check the engine tag I'll get some more
cat171
The dip stick is an easy spot as soon as you open the bonnet (if it still has the original one etc) as Terryc says, white on a Williams engine.
I geeked out on it in this thread ll!!
Good luck with it!
  Clio Mk1 1.8 16v
Good luck with it!
Cheers for the link. Just been reading through it.
