Amos91
Honorary Member
Got the chance to finish fitting a new battery tray today after I noticed mine had one of the mounts snapped off. It's made a noticeable difference the the gear change and power delivery seems sharper, it had been moving around a lot going by the wear mark's.
They can be a bit weak. Snapped mine clean in half at a track day a few years ago.
DomP182
  ph1 172, Arctic182
It was missing the one rear fixing entirely, I dont think it had been there for a long time, not even a bolt in the rail
VenomUK
  Clio 172
Flew through the MOT today. No advisories 🙌🏼
VenomUK
  Clio 172
Cover your numberplate even though it’s in your profile pic 😂
Photo was taken using snap, but good to know we have a stalker here :ROFLMAO: 10 cliosport points for you my friend Or were you just making sure I wasn't BSing about the no advisories :D
Sash
  A Yellow One
Popped down to see the guys at TyreSmart in Witham, Essex again today.
They did a grand job on the Clio so decided while I had the Megane out of the garage and some spare time I would get her alignment sorted.... any one for off the scale Toe out?! 🤣🤣
  Clio 172 ph1
Got the car on the rollers yesterday.
Engine is stock except match portet inlet, full flow cat, 2,5" exhaust and airfilter.
AC and PAS removed.
Anyone that can guess the numbers?
Eddie555
  Q7 2018 & 172 Cup.
Snap took mine for a power run at EFI
Ah.. nice to meet you today... It was me...
Final results at Efi today after the recent mods of:
197 cams with 8 degree inlet advance
Port matched inlets
Ramair filter.
Epas
Already had at last dyno at 176bhp
TTV lightened flywheel
Arp conrod bolts
Ktec cat back resonated recess exhaust
Today it finished mapping at 189.3bhp with standard 172 injectors running at 95% and safe... Engine mods finished for the foreseeable so time to just use it...
Sent from my SM-G977B using Tapatalk
497adam
  clio 172 phase 2
Port matched inlets
Ramair filter.
Epas
Arp conrod bolts
Today it finished mapping at 189.3bhp with standard 172 injectors running at 95% and safe... Engine mods finished for the foreseeable so time to just use it...View attachment 1460104
Yeah nice to meet you mate
497adam
  clio 172 phase 2
That's a really good torque figure for a 1*2 isn't it? Mostly seeing around 160 ft lbs, 252nm is around 185?
Must drive well!
Peak power is really down the Revs compared to most
  Clio 172 ph1
Must drive well!
It drives really well. It will be compared to 4 other Clios and a bunch of 206 RC:s in the end of April when our series finally starts :)
497adam
  clio 172 phase 2
I have no idea [emoji1787]
Yeah looks like the graph is shifted 1k lower, couldn’t work out why your peak power was only 5.5k. Because of how you calculate bhp from torque the graphs should cross at 5.2
MarcB
  182 Trophy & 197 F1
Going to get this fitted and sorted and then get the thing built back up.
Mr Trailer Man
Finally got round to fitting the Spa Design oil gauge, seeing as there's nothing else to do in the current situation.
Originally planned to mount it in an A pillar pod, but had a quick look at the panel with the cruise and esp switches and thought 'it'll fit there'.
Just have to play with the settings now and change the display colour and stuff.
DomP182
  ph1 172, Arctic182
Stripped the rear interior out to check over and treat my sills again only this time with BH Hydrate 80 and S50. Pretty tidy for a once neglected 02 plate
MLB
This must be the most boring and time consuming job so far.. Makes a big difference though!
An hour and a half in:
MLB
Ah sorry, yes that is actually interesting info;) I'm using Gyeon Trim.
Washed with soapy water and APC, then Gyeon Prep and applying Trim with cotton buds.
d19wood
  Clio 172 T , Megane
Let us know how it holds up once it's been in use a while please, not sure what to use to tidy the grills when I get the car painted
Looks good though👍
Washed it and cleaned inside the door gaps. Gummi pflege'd all the door rubbers. Polished the miltek. Tried to clean the alloys but winter has ruined them. They are beyond saving and need refurbed. Noticed the rear heat shield is hanging off. The miltek is squint and someone has put a tie wrap on one of the hangers to try fix it, which hasn't worked.
I need to get some tar remover. Are they all much of a muchness?
Maybe some tyre cleaner too, because they are very grey and manky
DomP182
  ph1 172, Arctic182
Looks lovely to me, rare to see flamers too so definitely a keeper!
That was the pretty side, its cosmetically a bit rough but I dont care anymore. Bit of bodywork one day maybe. Sills are good though!
DomP182
  ph1 172, Arctic182
Painted my rear calipers silver to match the fronts I did a few weeks back, bled them all again to try and get the slight spongey feel gone but I've still got a bit of travel before they bite which is annoying.
Discovered when I stripped the scuttle down to seal the leaking heater box I've either left the screen wash pump unplugged or something- no washy!
