Thought I'd update this. I did an LED dash conversion on the dci using bazillions of SMDs. The radio has a bad connection on one pad and as the buttons are lit up in series they now won't illuminate. I'll sort it when I get a chance but even without that the interior is a million times better with fresher lights. Some of them are a bit bright so if I were being anal it would be nice to have some marginally dimmer LEDs. I went for red displays and white buttons as I did in my previous DCI and it took me a couple of hours to do.
LEDs are as follows. All are 3528 in size which I got from ebay. The conversion costs about £8-10 in total. Original link here https://www.cliosport.net/threads/led-conversion-complete-list-of-led-bulbs-please.775521/ but I've updated it with me knowledge.
Clocks (needle type)
10 plcc-2 (4 for display, 6 for needles)
Clocks (digital ph3 type)
4 plcc-2 for the needles and 4 plcc-4 for the display
Digital
4 plcc-2 for needles
4 plcc-4 for display
Update list display
4 plcc-4
Tuner list display
2 x 509t LED bulbs
Climate control
28 LEDs all plcc-2 careful as two of the vent directional LEDs have the opposite polarity to the other 26.
Manual heater control panel
2 x 509t LED bulbs
Radio
11 plcc-2 with contacts bent out as they solder on the other way
Window switches
3mm dome topped led although flat top is fine
ESP/Cruise switch
3mm dome topped with inline 420ohm resistor to allow 12v
Central locking button/rear window heater
3mm led dome topped, again flat is fine
I did video it but was a bit miffed with the outcome so haven't done anything further with it yet.
In recurring news, the flashing on the dash from the fuel system is getting bad now and seriously awful when it's got two bikes on the roof. It struggles with overtaking anything and pick up is so slow it's painful going from the BM to this, an 1/8th of the power... The injectors are also loud and the bottom end of the engine is giving me the slightest of knocks on deceleration. The parts for doing a full fresh on the car have nearly all been ordered now so I'll be doing that in the coming months but it's a pig of a job so I'll be doing it with the idea of it being the last major work I do on the car for forseeable future. I'm pretty done with spannering on dailys now so once this is done I'll probably call it a day. The big ends, injectors, pump, clutch, water pump, belts and A/C will all be done. Yes it's expensive but it's a car you can't replace for what we're going to spend on it.
I did have a bit of issue with the steering wheel recently when the 2mm washer for steering wheel deformed and made it come ever so slightly loose. I've order a new washer from lasermaster which is 5mm thick so will be fitting that in the near future.
That's all for now. Lots of updates when the fuel stuff is done.
G
Digital
Update list display
4 plcc-4
Tuner list display
2 x 509t LED bulbs
Climate control
2 x 509t LED bulbs
Radio
Window switches
ESP/Cruise switch
G
