BoatNonce
So, I’ve just got an LG B9 and I’m having all sorts of issues.
1. Can’t set 2k120hz or even 1080/120. Max refresh rate in Nvidia control panel is 60hz. I would assume it’s not a HDMI2.0 cable, but it can do 4K HDR.
2. I’m guessing the above is the reason, but when setting Assetto Corsa to 2k120 it just sits in the top left corner and the display stays at 4k60 after flicking to black for a sec.
3. HDR disables when playing Assetto and only re-enables when I change volume and the volume bar comes up.
4. Playing 4k HDR files in the film and TV app freezes it immediately, VLC glitches occasionally. But the photos app plays it just fine.
Anyone got any ideas?
FIXED IT!
1. Has to be the one under PC resolutions. Both 2k120 and 1k120 work fine.
2. Can't fix that. Don't know why. But if you set the resolution for windows as a whole first then do it in Assetto it obviously then works.
3. HDR works in all resolutions now, can’t remember what I tweaked lol
4. Turns out the 'process video to improve quality' slider in windows settings being off doesn't improve performance, it stops it using the card. Works fine now.
Assetto Corsa, at night, at Le Mans, in M8 GTE, in HDR, at 120hz, is AMAZING. Very happy!
