Heater matrix change
  golf
Anyone done it on a 172 cup? Got a small puddle behind the centre console of liquid, gave it the taste test and it’s coolant.
Any guides on how to pull the whole dash out? Found the one for the top section already.
Any tricks to do it with the dash in situ?
I took the lower dash out and loosened the support beam, not sure the exact name for it. You might as well take it out as it makes things easier overall :)
  golf
Starting it this weekend as was busy last! Will update when I’ve sorted it or set the Clio on fire in anger
chris carenduff
  clio 172 clio 197
Hi mate sorry to Jump on your post, did you manage to get the matrix out ? Did you remove the full dash ? My heater matrix is leaking on my 172 cup so will have to change it soon. Thanks
David172
  Clio 172 M135i
Steering wheel will need to come off along with the squib. Basicly pulling the entire front of the interior apart. Good luck :)
Martin_172
its actually not a bad job removing the dash, just time consuming lol
dash top off
dials out
steering wheel off
radio out
trim that goes around the gearstick and houses the cup holders etc out
disconnect connectors from hazard panel, cruise control panel etc etc
disconnect connectors from climate control panel
unbolt all the bolts from dash (take pics on what way cables and earths are routed to make it easier to reassemble but generally they all seem to logically go back where they should.
chris carenduff
  clio 172 clio 197
Sorry guys just seen all these messages. Thanks for reply. Yeah it shouldn't be that bad as mostly all the interior is already out of the car as it's a track car. Thanks @ Martin_172 David172 and ZachB
  Clio ph2 1.2 16V
Hello.
I also have changed the heater matrix on my clio 1.2 16V 2005. But now i am experiencing leaking from the hoses that sticks on the plastic tubes on heater matrix. I have looked inside and saw 2 oring. Does any one know what dimensions are they? the plastic tubes on heater matrix are outer diamete 20 mm so im thinking the orings should 19 mm or 20 mm. Any help is much apreciated.
P.S.
Sorry for my bad english.
