Evo 6 GSR
Yep! That's for two though.
You need two sets, obviously.
yeah yeah i got that bit
cheers!
Car looks wicked by the way!
Get slide on spacersThread bump! As I have a UR200 (not this one) thought I may jump in rather than a new thread. @Christopher
With the 25mm H&R bolt you hub spacers, is it okay to run stud and nut kit directly in to the spacer? Or better to get the longer stud and nut and slide on spacers?
Opinions welcome! Thanks
Bolt to hub ones are dogshit and scary when they come loose! My H&R ones failed and the inserts came loose
No the actual inserts that are pressed into the spacers cracked loose mateThey shouldn't come loose
I put thread lock on mine and they stayed put.
There's steel inserts that go into the ali and they just span so you couldn't actually ever get a definitive torque
YeahOh ok, my bad. That's a bit s**t![]()
