The Power PC Thread [f*ck off consoles]
Daz...
  Inferno 182 Cup
Had a little play around this evening. Downloaded MSI Afterburner and MSI Dragon Centre. Whilst I have RDR2 downloading I wanted to whack the fans down a bit as they were a bit loud, so I’ve turned it from extreme performance preset to silent which obviously reduced noise. But I still hear a bit of a whine/buzz noise. The pump was cool but the gpu case was pretty hot, despite only being around 45-50 degrees on idle. Is it common for gpus to make a buzzing noise?
You can get coil whine when a GPU is under load. But it shouldn't be doing it when idle.
  172 Turbo
GTX 1070 minimum now-a-days tbh. Or the Radeon equivalent.
That's the thing, I rarely play games on the PC, but I'd like to be able to load most? I don't even know what's out there, my monitor can manage 1080p.
Perhaps, I should send the processor back, seems like this could get expensive.
Decided to save my money back in June and return my Ryzen 3600 today bought a 3070 FE. Probably should've just bought the 1070!
Current spec is Asus M5A78L-M/USB3 Motherboard, AMD FX6300 Black Edition 6 Core and Radeon HD 7870 :D
Grandpa Joe
If the new GPU will run on your motherboard then yes you will have a CPU bottleneck but the game will run ok.
Ray Gin
  Tesla & Impreza
It’s definitely coming from the gpu I just checked. Made a video and you can hear the noise clear as day when I hover the phone over the top of gpu. I’ll live with it for a while then upgrade I think.
sburrell93
Scotland - South
I've had coil whine from running high FPS in games. Happens in menus etc if I unlock the frame rates. Could be the installer for RDR2 was running at a ridiculous frame rate and that's causing it? I've seen like 500-800fps on game menus and my GPU sounds like it's about to either take off or blow up 😂
N0ddie
  Tesla Model 3
My Asus Strix 1080Ti (now my son's) is pretty bad for coil whine. Though did only do it when worked hard ie. Overclocked and utilisation over 95%.
Rojer
Make a custom fan curve, the problem with Ryzen is that it idles around 40 degrees, then when you do something it spikes up for a sec and that ramps the fans. It's hard to get it consistent as i was messing about yesterday and got it close as i can for now. I guess if you just have it set to a certain fan speed all the time regardless of temp that works too.
You seem to have very similar parts to me so if you need help drop me a PM.
Ay Ay Ron
Thought I'd chuck this in here instead of making a new thread.
Currently using powerline adaptors. My router (sky) in the dining room only has 2 Lan ports. I've got both of those running to two plugs in the lounge. I've got the Sky and PS4 plugged in to those.
I'm getting a PS5 and a new TV and will want these hard wired in. I've seen these splitters but I'm not sure if they are any good? I don't fancy having to shift the router to the lounge as there's not really anywhere for it to go and I'll have to drill through the walls.
This is what I've seen on Amazon.
I've seen boxes too with 4 sockets too but I don't think I need that many.
Any other suggestions?
Ay Ay Ron
Cheers lads. That’s the box I was on about. I can run everything off one LAN then and maybe use the other plug to get internet to the summerhouse (if it’ll work)
I’ll probably upgrade the router at some point but I’ve heard nightmares of using sky broadband on a non sky router. Probably fixes for that but I’d probably have to ask my 5 year old to do it instead 😂
How have you got your powerline adapters set up? I’ve only got 1 plugged into the router and 3 around the house. I think I can add up-to 16 and pair them all to each other as long as they’re all on the same electrical circuit.
N0ddie
  Tesla Model 3
Anyone manage to get a new 67xx?
6800 you mean? Canada's biggest seller of electronics didnt get any for launch day (today). Can't see many being available tbh. So much for the shade AMD threw onto Nvidia for not having any stock available at launch.
Daz...
  Inferno 182 Cup
I imagine it'll be 3-4 months, at best, before a decent supply of any of the new GPUs are readily available.
Ay Ay Ron
I've got two LAN cables coming from the router to two powerline adaptors (in the dining room)
I've then got the two recieving adaptors in the lounge with a LAN cable in each, one going to the PS4, the other to the SKY box. Both TP Link ones I think without checking.
I thought you had to have one for each LAN socket in the router.
I think it depends on the model of powerline adapters. I’ve got these TP Link ones: https://www.amazon.co.uk/dp/B01BECPIMC/?tag=cliospnet01-21 they’re a fair few years old now so I’m sure there will be a newer version out.
I use a short patch cable out of the powerline receiver in the lounge straight into a Gigabit switch which I split off using 3 more cables to my TV, Xbox, Sky etc. It might be worth checking what model of powerline you’ve got but I think a switch would be worth while.
The Psychedelic Socialist
I'm really liking the look of the new 6800XT:
Not as good as the 3800 at 4K, but mostly better at 1440p so given my monitor is 165Hz@1440p it'd be ideal as an upgrade from my old 1070 Ti, especially if I take the opportunity to upgrade my CPU from a i7-3770K to a shiny new Zen 3 5900X.
Shame none of these are in stock anywhere...
Mavez
  Clio & No Megane
Can't wait to pick up a 5900x and 6800xt in the new year. Benchmarks are showing great performance, also solid Linux kernel driver support.
Ray Gin
  Tesla & Impreza
Do people think there’s a reasonable gap between the 3080 and the 3090, for a 3080ti to be justifiable? (Assuming the rumours are true and a ti version is due out early next year)
I want to upgrade gpu soon, but don’t know whether it’s worth waiting for a possible 3080ti or just buying a 3080 now. I’m not sure I’d get my money’s worth from a 3090 on a 170hz 1440 monitor.
boultonn
  911 GTS
Don't underestimate supply demand, given how long the 30 cards have been out and trouble sourcing one, it's likely to be similar if a Ti came out so you might end up waiting til middle of next year for a 3080ti.
If you're gaming at 1440p, it looks like the 6800XT is actually faster than the 3080 anyway (particularly with a Zen 3 processor) so any 3080Ti is probably only going to end up being around the same performance anyway.
I'd be getting in the queue for a 6800XT now.
Grandpa Joe
You're move Nvidia...
Great performance considering it's cheaper and uses less power. Can't wait to see what the 6900XT does.
charltjr
For 1440p gaming, 100% unless you really want to use the RTX stuff. Apparently it's less clear cut at 4k.
It's moot point because you can't buy any of them anyway. :ROFLMAO:
boultonn
  911 GTS
Isn't 1440p the gaming sweet spot rather than 4k?
For most people, I think so,
Getting 120+fps in 4K with good graphics setting requires some pretty expensive hardware, however you can run 120fps in 1440p with ultra settings for a far more modest budget, and it's a big leap in both resolution and graphics from previous gen consoles.
