Megasquirt fuel pipe size
Car  Clio track car
Hi, I am looking at fitting a megasquirt set to my F7p engined project car , in the instructions it recommends to use 10 mm fuel pipe both feed and return, but the fuel pipes fitted and crimped to my engine are roughly 6/8 mm bore , has anyone any ideas or advice on how to sort this problem , many thanks David.
Sounds fine as is tbh 8mm id will easily be enough, an6 if your changing all the lines
Thanks for that , the feed and return pipes have a red and a green adapter in the end of the pipe , which is the feed and which is the return? Thanks David.
