Cleaning/painting engine parts
Yarp
  182 Turbo, E46 M3
I’m in the process of stripping my engine down and want to tidy it up when it goes back together. What’s the best way to clean the parts back to a decent finish and then protect them?
Am I best to get them aqua blasted or something similar then lacquer them or is there a decent paint anyone has used to cover them? Parts will mainly be mounts, rocker cover, brackets etc. The big bits like block and box will just be painted.
Mr Underhill
Could do to be fair. There’s a place down the road that does it. Would it be ok on the rocker cover though?
If you’re wanting an OEM look, take as many alloy pieces off as possible and get them aqua blasted. For colours - as mark suggested powder coating.
Rocker cover can be aqua blasted if off the engine but I just use a degreaser, wire brush, then get a fine brush and stick some VHT engine paint on.
This is mine. Gearbox degreased then painted with VHT. Sump, Upper and lower inlet, fuel rail, thermostat housing all aqua blasted.
Mr Underhill
Also on the engine block I degreased and cleaned it up, then gave it a few coats of Hydrate-80 before painting it. I’ve found if you don’t do that, the engine will rust through after a month or so.
Mr Trailer Man
You can get enamel/epoxy based paint for doing the engine block, but it's expensive.
Eastwood Aluma Blast gives a nice aluminium looking paint finish on all the silver parts.
Mr Trailer Man
This is the stuff i was thinking of, not as much as i thought
Prep the block with this as it leaves a zinc phosphate coating
Mr Underhill
Used that Metal prep as well.
I prefer the Hydrate-80 on engines as you don't have to faff about washing it off. A couple of coats leaves a really rich Black protective coating. And paint sticks to it like glue. I throw it on everything now :LOL:
Flob
Thats the Eastwood Aluma on my inlet manifold after about a year. I would use it again.
Flob
This is block brush painted with some VHT engine block enamel - still fine several years later having gotten dirty, jet washed off, covered in PAS fluid when my pump died. The engine block looks about the same still, certainly no rust. The rocker cover was painted using some eastwood cast steel (I think) paint and thats been s**t, while the aluminum eastwood paint has been durable.
Doing it all again I would take a boot full of parts to a vapor blasters and pay the money, I'd probably 2K paint the bits next time round too.
