1*2 Front Grille Alarm Switch hole
hopgop1
This may be a silly question, but I've got a replacement upper front grille for the bodyshop to replace when I have my front bumper resprayed, but there isn't the hole for the UK spec alarm switch. Does anyone have a spare grille lying around that they could measure the hole for the alarm switch please, so I know what size to drill, or does it clip into something else so the size doesn't matter?
Don't want to accidentally make it too big and not be able to clip the alarm switch into it if that makes any sense.
It's only a small hole for cable to pop through isn't it?
Body shop should be able to line it up from the slam panel underneath and drill.
I'm sure it's got a 1 inch shroud around it too
Thanks for the help, had to contort my hand around the airbox but I did get the switch unplugged and out quite easily. Hole measured (~20mm) and drilled in the new grille, ready for the bodyshop.
