172 / 182 Throttle Pedal Wiring
  172
Evening guys / girls / other,
I don't suppose anyone has the pinout for the late 172 / 182 throttle pedal?
I seem to have Pin 1 and 2 as grounds, Pin 3 as signal 1, Pins 4 and 5 as 5v+ and 6 as the second signal, but I am not sure I trust my notes and can't get on autodata at the moment.
If anyone could help me out I would appreciate it hugely, thanks!
  172
If anyone ever searches and needs it, I've included the throttle body as it's related.
Pedal:
Pin 1 Sensor Ground 2, ECU Pin 75
Pin 2 Sensor Ground 1, ECU Pin 87
Pin 3 PPS Signal 1, ECU Pin 14
Pin 4 +5v Reference 1, ECU Pin 6
Pin 5 +5v Reference 2, ECU Pin 71
Pin 6 PPS Signal 2, ECU Pin 43
Throttle Body:
Pin 1 TPS Signal 1, ECU Pin 17
Pin 2 +5v Reference, ECU Pin 7
Pin 3 Motor +, ECU Pin 61
Pin 4 TPS Signal 2, ECU Pin 14
Pin 5 Motor -, ECU Pin 62
Pin 6 Sensor Ground, ECU Pin 82
Cheers!
Tom,
Hardwired Performance
  172 Ph1
Yeah , you got my reply I see on FB
  172
I haven't been on Facebook, I pulled this off autodata this morning.
Are you the chap who offered an ECU base map yesterday? Having trouble with one from the ECU dealer. If so, thank you 👍
  172
Autodata pic attached below, bit more typical of normal wiring diagrams than the Renault version it seems.
  172 Ph1
Are you the chap who offered an ECU base map yesterday? Having troubled with one from the ECU dealer. If so, thank you [emoji106]
No wasn’t me .
Just mistaken you prob for someone else on FB .
Saw a post asking the exact same question.
Must be common lol [emoji38].
Hope you fixed the issue.
  172
Haha fair do's, either way, between your pic and mine and the pinouts, hopefully this will save some questions in the future.
All the best 🙂👍
