Acid rust removal
R3k1355
Saw this on TikTok, thought it was worth a shot. Have tried Vinegar/Coke method before but it was slow and results weren't exactly amazing.
This uses toilet cleaner, specifically Harpic (it's 10% Hydrochloric acid) as bleach based won't work.
Obviously I wouldn't try this with anything coated, or ali/alloy/plastic as it could well ruin it, and you'll want to paint them after as it'll rust pretty readily.
I wouldn't bother with basic bolts/fixings, but some stuff can be dealer order only, or NLA, or just kinda expensive for a few stupid bits.
Stuck these in a jar of the stuff and left it for a couple of days
Flob
Citric acid also works spot on, mix up a little bit with water and stick it in the solution for a couple of days and all rust is gone.
Cheap as too if you buy big bags of citric acid powder off eBay. I got a little fish tank heater for the tub so I can leave it outside (can smell a bit). Heating to 30-40 massively speeds the whole thing up.
Good for removing limescale from kettles too!
R3k1355
Got some Citric Acid off eBay to give it a go. Results were really good. As you might imagine it's milder than the Hydrochloric acid in Harpic, so it's no quite so critical how long you leave stuff in there.
I found on heavily rusted bolts it forms this greyish sludge, where the Hydrochloric acid just powers right through. You can just pop those bolts into some Harpic and they come out beautiful. It seems quite good at removing residual paint as well, so small brackets and stuff come out very well.
As with HCL the Citric Acid will remove any Zinc plating on bolts, so be aware what you're putting in and how you're going to protect them when they come out.
I made the solution up at 10% weight/volume. A 250g bag of powder was £4.50, enough to make 2.5L.
Brigsy
  T.Turbo
Works spot on if you have time.
I believe you can mix it up with wallpaper paste to make gel if you want a cheap version of BH deox gel.
Paddy_g46
Ant idea how this would react with car paint? Like if you wanted to use it in some very small localised rust spots?
R3k1355
Yea go for the Gel, the 10% citric acid (in water) solution wouldn't stay in place, it'd just run off and cause bother.
If it's a little spot can you hit it with a dremel or something?
loggyboy
Electrolysis is the better route as its actually reverses corrosion and can convert metal thats partially corroded back to a better state rather than eating away at what could be good metal.
