Clio 182 turns over, won’t start.
Car  Clio Sport 182 Sport
At wits end. New starter motor, new injectors, new alternator, new earth strap (gearbox) on the way as the current one is fairly green. Going to buy some relays next week. Battery is good. Is there anyone in the North East that can help if the strap and relay’s don’t fix the solution?
That video appears to be a bit jumpy for me, so can't tell, but is the immobiliser light going out?
Sorted now. Ignition wasn’t recognising key. Did the following and it worked….
It could also be a sign that your key is on the way out. For the first 6 months of my ownership, to start the car I had to hold down the lock button when turning the key in the ignition. Eventually it stopped recognising the key, and I had to take the car to Renault for a new key to be coded to the car (cost around £200).
Just worth bearing this in mind of it plays up again.
