Clio 182
Little while since I have updated but managed to find a perfect condition climate control unit for £20 delivered
All fitted so just need to be careful with the buttons to keep them from getting worse!
Also bought some spacers - 18mm front and 5mm rear which are now fitted
In truth, I think the rear could do with a little more so will probably end up with stub axle spacers at some stage. Am I likely to end up having issues with the rear wheel bearings when removing the discs as these were brand new a year ago..?
I am having some issues with the front arch clearance below on the lip of the bumper. Any tips or is the answer to simply raise the car / live with it?
Also feel like the front could benefit from a tad more camber, currently measured at -2.4 across the front. What's the general consensus on this?
A friend has suggested staying below 3 degrees as at that stage he sees excessive wear. Its purely an aesthetic decision as the car drives really well still..
Going to give it a little love this weekend in anycase as I havent been using much given the lack of air con!
