Clio RS 200 cup advice needed
Car  Clio RS 200 cup
Hi, new to the forum, just need a bit of advice on a few things that are recommended for my Clio 2010 cup.
It's got a Miltek exhaust, Rs tuning map, standard OEM cup suspension, Zpo shifter. Currently on 97k miles, drives really well for the mileage. What front brake pads/discs are recommended for fast road use? I only really drive hard on the odd weekend over mixed A -B roads. Otherwise she's just steady away around the doors now and again, any advice will be appreciated.
I run brembo oe front discs and mintex m1144 front pads, perfect combination imo for a fast road car, not overly expensive, easily available, work well from cold but a big step up in performance over the factory setup
I'm wanting to keep the discs O.E spec, had bad experience with cross drilled stuff in the past, I did see the Yellow Stuff pads, any thoughts? Cheers
I had M1144s on my 172 when I got it and did my first two track days with them. They weren't that bad, only fading after 15 or 20 minute stints at Bedford.
