K4M RS Intake straight fit?
  Np200
Yo guys I got my hands on a Twingo RS intake manifold. Would like to know if it is a straight fit on a normal K4M that comes out in the Clios.
Thanks
Danith
  GTi 7.5 pp/Mx5 nd2
Thought they were all the same. Isn't it just cams and mapping that make it a bit more bhp? Might as well match them and tart em up
Martin_172
The inlet ports should be the same spacing as I'd imagine the blocks are similar, depending on what age your current k4m is it will have either a cable throttle at the rear of the inlet, an electronic throttle at the rear of the inlet or an electronic throttle at the right hand side of the inlet (like the RS).
The breather setup is probably different too, I'm sure it can be modified to fit though!
  Np200
Thank you! Yes it fits, but I have idling problems now, dont know it is a leak but currently busy to find the problem. The car sounds much better, and pulls wayy better.
Danith
  GTi 7.5 pp/Mx5 nd2
twingo power, lolz
The intake manifold makes it sound better? This twingo RS I have is super grunty I've noticed
  Np200
Yes it is very grunty, i am inlove with the sound. Power doesnt dip before redline anymore, will keep posted on how much KW and NM is actually gained.
twingo power, lolz
  Np200
Since the video and foto, i build an induction nothing fancy. When it is sorted 100% I will be looking to build a nice one.
Ps. foto and video was the day when i got the Bakkie(small pick up) back.
  Np200
  Np200
  • 0391c82a-8e9d-4f96-a99a-b4c7f11c6870.mov
    4.5 MB
  Np200
Thanks man!
Just looking for more advice on the ventilation needed. As I had a seal on the tappet cover pop off, do you just bridge the intake pipe to the std one? Guess it will be fine then?
  Clio 1.4 16v
Do you have more photos how you fit it to lower intake manifold and how you fit throttle body? Thanks for reply
Thanks man!
  Renault Clio 2 k4j
Hi guys , im about to do the same stuff to my clio mk2 1.4 16v , upper intake manifold and throttle body from an twingo rs , lower manifold from megane 2 1.6 16v also the injectors and the injector ramp (to get a complete manifold in my country is rare this days) also you need this rocker cover part from renault modus (8200294042) also the 90 degree rubber induction hose from the throttle body , if you want you can ut the twingo rs cams put the intake one yu need to plug the vvt holes ...for the exhaust part i nned to find an standard exhaus manifols from a twingo rs to see if i can fit it (abs pump is quite close) if yes k tec has a nice manifold on sale.
  Renault Clio 2 k4j
Some pics
