Service for the 197 was due is Feb and kind of forgot.
Now serviced with new filters.
Treated it to a much needed jet wash, quick claying, polish and wax. Also sorted the headlamps
And replaced the standard HU for a Kenwood 🙂
Oh and upgraded the speakers in the rear!
Tidl; stud and nut s**t.
"they make fitting the wheels much easier". No they don't, they make it a right piss about. 6 of the c***s came out. 🙄
Til; turini's 😁.
Aye, they're a pain if not looked after.
I find they need coating with ACF corrosion block a few times a year to stop them seizing up and winding the stud out.
Same happened to a mates Megane on a track day and it was a right f**k about.
I’ve fitted this eBay special gear knob, although reverse collar doesn’t seem to be going back to its position properly (original spring is back in position)
So might be going back to my ruined standard one!
I have tried these ebay specials before they never feel right, I reccomend getting the original retrimmed by snappy.
Yer that’s what I’m looking at doing now, retrimming is expensive but a lesson in buy cheap buy twice for me
Possibly the last clean of the year. 70K miles, standard apart from Xenon headlights and Ktec Stealth exhaust. On original Cup springs looks a bit 4x4 but such an nice ride! I've toyed with the idea of selling but will most likely get tucked away till next Spring.
Noticed my power steering pump was a bit noisy so checked the reservoir…. It was nearly empty.
Just jacked the car up today and I think I have confirmed my fears.
High pressure pipe is leaking???
Am I right in my assumption and is this part NLA?
ETA… Still need to get a thread up for this car.
Aye NLA sadly.
There’s one here https://www.ebay.co.uk/itm/35495133...nwx-nP3Rjy&var=&widget_ver=artemis&media=COPY
Part number is 6000073688 for reference.
Top man!
I had Birchdown asking me if it was a SMI rack. Is there any way i can determine this and make sure that the link you have provided is compatible with my car? They also mentioned a white tag. It’s been over a decade since my last cup so I’m a bit fuzzy with knowledge.
172/182. Is yours a 172 CUP?
Work Hilux.
Parked in a nice corner spot right close to the bush to leave loads of space like a pro.
Struggled to get in and out walking past the bush like an idiot. So ended up clinging onto the wing mirror folding it in.
Noticed the glass was lifting at 60mph after that.
Pull it off to reseat properly and cracked it putting it back on.
Ordered a cheapo replacement.
Should of just parked normally I guess.
Yeah, those are the part numbers for your car.
Pirtek would be able to sort it.
Thanks for the replies appreciate it!
Is there any drawings of the pipes on here that I can use for them to replicate or do you know of anyone who has had one made up by them?
Ignore me, I’ve had a look on here and couldn’t see much about it apart from one thread where a fella got pirtek to make one so I’ll see if Birchdown can remove mine and I’ll pop it over to pirtek near me and get them to remanufacture it.
So for some nostalgia I have displayed the original tax disc and also repositioned the rear Sport badge
I've also got all the old tax discs in my car folder I'm tempted to display, need to spot a cool tax disc holder I like first though. Cool that it matches the plate too.
OG Renaultsport badge is crimincally under-rated IMO.
Literally just an eBay purchase, uses no glue etc… can’t go wrong
