182
Please could someone whose done it, confirm the two smaller nuts (13mm) on the upper gearbox mount are definitely 62Nm?
"Upper Gearbox Mount:
- Central nut: 62N·m
- Mount to Gearbox: 62N·m"
cliosport.net
(posted on the sticky so probably won't be seen, hence posting here as well)
Thank you
172/182 Torque Wrench Settings
1. Alternator upper support mounting bolt - 38Nm + 0.4 2. Alternator upper support mounting bolt - 32Nm + 0.3 3. Alternator/block tie-rod mounting bolt - 62Nm +0.6 4. Alternator upper mounting bolt - 32Nm +0.3 5. Alternator lower mounting bolt - 38Nm +0.4 A lot of the bolts in the illustration...
Thank you
