‘Bonnie Blue’ The RB 182
Hopefully tomorrow I will be fitting the following new parts - time permitting:
Rear Calipers
Rear OEM discs with bearings and Grams disc spacers.
Rear pads TRW
Hel Lines.
Replacement Exhaust Manifold to midpipe fitting kit
Powerflex Yellow Upper Engine Mount
Powerflex Purple Dog Bone
RS Tuner 98 Ron map.
Going to pop the wheel back off and check that the angle sensor is definitely on Zero as well. As the abs isn't working atm due to the sensor fault.
no progress today bar getting the new exhaust gasket in.
can’t really see how the hel hoses would attach as the existing hose is crimped and the unions to the calipers on the rear are seized solid.
So unable to do the rest of the bits as I couldn’t risk snapping the hose union and the new hoses not fitting ffs
So unable to do the rest of the bits as I couldn’t risk snapping the hose union and the new hoses not fitting ffsView attachment 1679732
The rears don't go on at the caliper mate.
They're to replace the flexi's at the rear beam connection under the passenger side.
Follow the hard lines and you'll see.
Ffs. I tried googling whilst I was in the workshop with no luck. I couldn’t see where they went?
Tbh, the existing hose is completely seized in the calipers, so I’ll need to replace the whole thing I guess to get the calipers off…
Some good news though, I’ve sorted the exhaust smell out
may order these for the rear… any of you gents used them ?
I got all mine from BRT.
List of parts I’ve purchased/fitted so far on the clio.
B&C coilovers
Super pro Camber bolts
Whiteline ARB
Hel lines front and rear
Corbeau seats, rails and runners
Weight in gear linkage
sump plug / washer
Seat receivers
Steering Wheel cover
Nuts and bolts for seats
Acf50
Glue remover
Millers Oil
Oem Renault oil filter
Voluntech steering wheel controls
Momo steering wheel boss
Sabelt Steering wheel
Dent removal
Brake fluid - RBF700
Rear SNR oem discs and bearings
Rear Bosch calipers
Rear disc spacers (Grams)
Trw Oem rear pads
Powerflex Purple dog bone mount
Powerflex Yellow engine mount
Wurths high temp exhaust sealant
New exhaust manifold to mid pipe gasket and fittings ktec
Proline replacement rear brake pipes
Remap
Rs tuner with all modules
Still plenty planned as well ☺️ next up will likely be matched inlets. 2118’s or Evo rims and ar1 tyres. JP half cage. Headlights. Paint bonnet and front bumper. Want to replace / sort / looking for a solution for the interior ‘sticky’ trims. That’s a definite want - to sort. Carbon splitter. Carbon tail pipe trims. Eventually LSD.
Longer term plans are to refurb all suspension components and polybush the whole car. Refurb subframe etc and beam. Although they’re not bad, I’ve just got ocd
Love to see this.
Helpful bunch. I remember totally F'ing up the airbag module thing and Russ (changes his user name every week) saved my arse.
Question for you. Where did you source your rear discs/bearings from?
Love to see this.
Ha, it’s not me that changes my username mate. It’s the nasty bigger boys that keep
Picking on me
Right. Hopefully I’ve got what I need now and can get on with a few bits with dependencies on the lines not being seized.
Slightly irritating my ocd that the colours don’t exactly match. But you won’t see it… atleast
Excuse my ignorance, what are the lines in the bag for?
They are the lines from the rear caliper up to the chassis mate. Then the smaller of the two Hel lines links the bagged up lines to the solid pipes. The other longer Hel lines are for the front.
You may not need to change the bagged ones generally as they are solid from oem.. BUT they go rotten and seize (the latter being the issue I have, so I've decided to change the lot).
Ah yeah I see. Mine are a little bit scabby so may take a look at replacing them at some point. The front and rear (over the beam) are braided already as far as I am aware.
it's a bit of an odd setup. Not sure why they didn't just braid the lot. On the rear you've got solid up to the union (for use of a better term) and then about 8-10 inches of rubber hose and then back to solid. Bloody french :ROFLMAO:
The bagged up ones are like 40-50 quid. So not bad at all. They're from ProLine. And are made by Hel anyway.
where did you find the bagged lines you have that replace the solid ones? thanks.
They're all stamped on. I complained to speedline about this and they sent me decals to replace if needed.
