Speedo Gonzales
NVMe?Any SSD recommendations for the Ally? 2TB ideally. An SSD and a carry bag and I’m good to go.
AyeNVMe?
Might be worth keeping an eye out on Amazon for a deal mate
You should be alright with that mate.Finally settled on my PC.
So far, I've bought the cooler, memory and PSU.
Hopefully get the motherboard, CPU and case and next month and then the GPU and SSD the month after and I'll be good to go.
Follow that up by the Moza R9 and GT Omega Prime Lite a few months after and that will be me ready.
Does anyone know if the Fanatec CLS Pedals are compatible with the Moza?
I have the CSL pedals and CSL V1 wheel, its just the DD they haven't delivered, which renders it all useless at the moment. I did have a read about the connectivity. I assumed it would all run through the hub. Guess thats how it works when using all Fanatec on the box? PC has the mix and match options.You should be alright with that mate.
The Fanatec software controls the wheel hub, the pedal base and any auxiliary items like the shifter and a handbrake.
It's entirely possible using that software to just have it for the pedal base alone. I did that previously when I had a set of Fanatec CSL Elite V1 pedals and used it in conjunction with my Logitech G27 at the time. The vast majority of titles allow you to configure non-connected devices to work together within the options menu.
I take it you haven't got the CSL pedals yet? If not, I would 100% recommend paying the extra for the load-cell equipped brake pedal. It makes a massive difference to the feedback within the braking zones.
The CSL pedals support both DD hub connectivity and USB connection straight to the PC. In fact, the latter is the only way that you can update the firmware on the pedal base. Don't connect both at the same time however, or else you can damage the unit.I have the CSL pedals and CSL V1 wheel, its just the DD they haven't delivered, which renders it all useless at the moment. I did have a read about the connectivity. I assumed it would all run through the hub. Guess thats how it works when using all Fanatec on the box? PC has the mix and match options.
Few options on the table now, the eBay Fanatec 8nm or go for the Moza R9 or Fanatec defy all the odds and deleiver on what I paid for
Did you run DDU and boot into safe mode before installing drivers? Sometimes they can mess up if you don't remove the old drivers firstjust got my normal NVIDIA reminder for the updates and noticed 2 things weren't going ok, the Graphics Driver and the HD Audio Driver both failed. Any ideas on why this has happened please?
Sorry I’m not a pc wizard, what’s DDU? I wouldn’t know how to remove the old drivers first, I’ve been doing the same thing I’ve been doing for a long time snd had no issues like this beforeDid you run DDU and boot into safe mode before installing drivers? Sometimes they can mess up if you don't remove the old drivers first
It's a program called Display Driver Uninstaller. It completely removes all traces of existing drivers from your PC so you don't get any weird issues when updating them. Try doing a clean install as @SharkyUK suggested above, but if it happens again then download DDU and try running that first.Sorry I’m not a pc wizard, what’s DDU? I wouldn’t know how to remove the old drivers first, I’ve been doing the same thing I’ve been doing for a long time snd had no issues like this before
A rough guess would be £5-600, depending on age?Guys what would this be worth?
Graphics: ASUS Dual GTX 1070 8Gb
Processor: AMD Ryzen 5 2600
Motherboard: MSI B450 Tomahawk
Ram: Kingston HyperX 2x8gb 3200MHz
Storage: NVme SSD WD 512 Gb
Power Supply: Corsair CX750M 750w
Case: Antec p101s (silent) with 4 fans
Guy wants £400 for it.£300 tops imo
If you have a GPU i have a HP Z820 Workstation i've recently replaced that should cover 3d modelling quite comfortable, Dual Processor/128GB Ram etcGuy wants £400 for it.
My little one at home I use for 3d modelling has just s**t itself big time, so I was hoping I could cheaply bridge the gap.
👀 how much for the 4090?Might sell my Gigabyte Gaming OC 4090 soon if anyone is interested. I've also got an unopened EK waterblock for it.
I'll DM you hun x👀 how much for the 4090?
I'm kinda surprised they're not doing a 4090Ti model to round the series off, 50 series cards are expected in about 6 months.
I'm looking at a new curved monitor around 34" but something that bothers me in fps game is the pixel pitch. Can you use say 2/3 (whatever's closest to 16:9) of the width of the screen in game with the edges blacked out?
Edit: Of course you cant duplicate pixels! Will need to go down to 32" with 3840x2160 at least..
Let me know what you think of it. I've got a 27" LG 4K monitor at the moment but I miss my old curved monitor and I reckon I could get away with 32" on my desk.@SharkyUK I ended up ordering the Gigabyte m32uc, 32" 3840 x 2160 curved. Being 16:9 I wont have to change the resolution in game.
100%I have to admit that I don't think I could go back to flat panels after using curved monitors for the last few years (for both gaming and productivity). I just find them easier to work on and more immersive for gaming. The only flat panel I have is a calibrated screen for graphics/design work but that hardly gets used these days.
