No brake fluid coming out of rear calibers
Ant1
Brembo! Brembo! Brembo!
Attempting to bleed the rear brakes using one of those Easy bleeders, it works as fronts have fluid being pushed out.
f**k all from both sides on the rear.
What am i missing?
If the problem persists I'd suggest using one of these bleeders before looking for a new compensator, had a similar problem on mine after fitting a new caliper, just would not bleed with pressing the pedal or pulling a vacuum, knew the compensator was good as it was new and the rears worked perfectly (well until the 1 caliper seized solid) used this thing & had it sorted in under 2 minutes
That’s what i have.
+1 for that compressor magic - my top tips....
  1. Make sure you have a good seal - wrap *loads* of paper towel around the engine bay because if it does go 'pop' ....
  2. Related to number 1 - don't go crazy on pressure. It's viscous fluid, not a f**king water pistol.
  3. Fill up 1.5L in it - while you've got it all hooked up, do a full flush.
  4. Use the 'loop' in the extractor bottle to go higher than the nipple, so that you have a gravity flow
My cup172 just had new rear brake lines and garage told me only one side of rear allowed brake fluid and the other side nothing, so needs a new valve. I am reading threads and wondered if anyone had tips or advice? Thanks
