This stuff is pretty good. If it’s still stuck try acid then. Just follow the guidelines and you’ll be fine
Recommendations for specific products to use on baked in brake dust? I've been told to try acid. Never had to use anything that strong before.
Few options here, in order of 'harshness':
Normal, non acidic wheel cleaner. A good one is a must. I like Autosmart Smart Wheels. non-acidic and actually works a charm!
Fallout/Wheel cleaner combo.
Fallout remover neat
(this is where things get more agressive)
Heavily diluted acidic wheel cleaner
Less diluted acidic wheel cleaner
Also worth considering a claybar as ive found they can do the job.
Cheers @Fantastic Nostrils . Forgot to mention i tried a bit of Iron x (which i believe is fallout remover?) on it but made no difference. Some purple came up but visually looked the same afterwards. It was very old stuff that'd been sat in the garage for about a decade, not sure if it loses potency. Didn't think to try clay!
Ill be honest and say that I didnt rate Iron X very highly. It was 'ok' but nothing id rave about. Ive tried many others, for less money ill add, that did a better job.
ValetPro Dragons Breath is one of the best, but expensive. Then again, if you're only doing wheels then its worth grabbing a bottle!
Maybe ping some pictures up if you can and ill share any thoughts I have
Please ignore the inner rims 🫣
This is the worst bit
oooooo she baked!
Yeah, that looks totally revivable to me from where im sat. Going to need some strong stuff to shift it but I wouldnt necessarily jump straight to acid.
Few rounds of some nice strong mixed Smart Wheels and id have said that would shift.
You can see where some of it has come away with some hard work, so thats why I think its doable.
What are the downsides of going straight in with acid (I watched a YT vid and the guy had to use full PPE!)? Saves me faffing around buying stuff that may or may not shift it after a few goes? Does this look too tough for the BH stuff @Crybert recommended?
Acid isnt as scary as most people think it is. But it does have potential to ruin the finish of the wheels - which is mostly why people tend to steer clear. Work one wheel at a time and DONT let it dry on. Multiple rounds of cleaning are better than letting it dry.
Its hard to say, I havent used that specific wheel cleaner I dont think. Ive never really needed to attack anything with acid before. Ive always managed with multiple rounds of non-acidic wheel cleaner or fallout remover
Acid f**king stinks. The BH stuff is smelly aswell but not as bad as acid
Do you agitate after putting it on?
Iron X stinks too so my assumption now is all wheel stuff stinks 😄
I've tried shampoo+sponge and iron x (no agitating) so far. It doesn't scrape off even with the fingernail.
Guess i'll try Smart wheels or maybe BH auto wheel next.
Not smart wheels.
Get the auto wheel. Bh are top of the game. @imprezaworks has some decent strong maybe acid wheel cleaner.
Oh and auto smart do something called Ali or Alu. That's their strongest wheel cleaner but use it more than a couple of times and the wheel will dull. Apply with a brush and agitated.
I haven't used it for a while as they stopped doing 5l (was about £20). They only do a litre and 25l now.
There wasn't anything this stuff wouldn't get rid of
I just use the strong autoglym acid cleaner in work, does the job.
+1 on this stuff.
It’s f**king savage.
Even diluted it keeps dissolving the mechanism on any spray bottle I put it in 🤣
That's scared me off if anything lads :ROFLMAO:
Guess i'll try BH for now (y)
The inners will definitely need the strong sh*t but i'd probably be better off just going for a full refurb.
At the risk of sounding like a boring wanker
Please PLEASE wear PPE (Gloves & Goggles at a minimum) when using acid.
You only get one set of eyes, lads.
EDIT: This comes from the dickhead that recently nearly lost an eye when a cutting disk exploded on my angle grinder and flew past my totally unprotected eyes. Theres a scratch on my headphones as the blade shard came flying past my face at mach 2......Guess who wears goggles now?
New 15m rubber hose fitted; from direct hoses 👌
Almost sent it back for it not being compatible but, turns out I’m just a mong. Was also confused by the weird red paste that was on the old hose when I took it off. Oh yeah, that was blood as I’d somehow managed to lacerate my finger whilst doing it. Anyway, done now.
I need a stiff brush to clean my floor tiles with
Any recommendations for a set ? There are millions of sets out there.
It's an old floor so needs a good scrub!!
Obviously hard to show on camera. But any of you wizards know how to get these imperfections out? If possible? Ignore the massive scratch lmao.
lots of small “dots” in the paint. I don’t even know what they are or how they’ve been created over the years. I’ve clayed it and now using meguiars ultimate compound with a DA but maybe not aggressive enough?
I decided to use a sample of a quick detailer (if that's the right name for it) I had rather than a proper polish last time I washed the car, and I was really impressed with the results, as well as cutting down a lot of time. I think it was from Auto Finesse. Is there a recommended one above that?
Thinking just snow foam, jet wash off, big towel dry and then a spray over?
I bought my dad one a a few years ago and he says its really good. He uses it after each winter to get salt etc off.
This is what I wanted to use it for, it’s always the bit of the car that gets neglected after a wash.
As we have an import for family duties with typical Japanese rust proofing (it does have some coating on it too) I thought giving it a rinse with one of these won’t do it any harm.
