Odyssey blue ph1
Ben perry
  Clio 172 cup
So after mechanically restoring my dads flamer I really had the itch for a ph1.. and after bit of time the one piped up that was lurking online with overheating issues and on 200k miles but was was fair he was asking so had to have a look as wasn’t far from me and yer was impressed.
I thought I could break it and make money (how I look at stuff as worst case😂)and yer got it back to my unit
So plan was to pull the engine do cambelt water pump as I suspected overheating was due to pump not circulating and while I was there I’ll do clutch and all the bits that just make sense but!! Plans don’t go to plan once engine was out I was turning engine by hand and it was like having the plugs out!! 😂🥲 weird as it ran sweet disregarding the over heating issue so next was pull the head off see what’s going or gone down 🫣 and bores were really good for mileage as was the overall visual engine condition once head was off pulled valves and 14 out of the 16 were leaking like a siv..
So new plan picked up a 60k bottom end and a new set of valves and a victor rinze head set so should be sweet when done been picking up few little mods to on the way..
And yes the pump was ded 🤑🤑
Cheers for reading!!
Struggler
  Ph1 track 172
Would love to have a unit like that! maybe one day!
Car looks in good condition externally! How are the arches? Definitely need to keep these ph1s going ;)
Ben perry
  Clio 172 cup
The car looks pretty clean, what's it like?
Cheers yer mate it’s a 10 footer doors and quarters let the car down but as far as rust go it’s really good!
Yer mate unit makes its nice 😅
As said it’s clean I’m gunner put a pair of quarters on it when weather warms up as that would mint it up
Ben perry
  Clio 172 cup
Cheers mate the colour is a winner for me and yer it’s pretty fucked but I don’t mind 😅 it’s a survivor!!
Ben perry
  Clio 172 cup
bit more done got pushed out side and fully washed the under side and engine bay with TFR all cleaned up really well next I’ll pull rear beam and tank of for powder coating and treating and under sealing..
few other bits fabricated cup panel and front subframe captives completed it m8
Hopefully should have my valves for engine tomoz 🤞
Ben perry
  Clio 172 cup
Little update got All my new valves lapped in nicely so head will now be going for a light skim leak testing and a good clean along with other engine parts..
Also cleaned the block right up with a needle gun treated and gave a lick of hammerd black looks nice tbf
Next I tripped all the back end down for treating underselling and powder coating
Nice and clean
Ready for the powdercoaters
That’s all folks 🥕
gudger12345
  Ph1 172
Unreal progress
i need to do the rear end of my ph1 once i get my 2 post lift installed
how did you remove the rear beam and keep the oem bolts in positon
previously i have always had a nightware when it came to removing the rear beam
Samholmes88
  Clio 172 ph1
Going like a boeing here pal, good on ya 👌 wish I had a 2 poster int garage, about skinned my back already. Ive got back end to drop off mine once the front is rolling and can turn it around! Any tips for a rookie 😂
Ben perry
  Clio 172 cup
Cheers mate I have been slack as I’m only just dropping bit off to powdercoaters 😅 although head is now been skimmed and tested just goto get all the engine bits cleaned 🥵
And as for the beam..
I have done a few and have been successful with every go!!
so firstly wire brush on a drill lots!! on the exposing threads
Next soak threads with oil I prefer to use engine oil in this case as it doesn't dry out
Next befor I attempt to undo the nuts I ran a thread chasing nut (m12x1.25) I think!!! Need to double check!! up the exposing thread to clean I do this couple of times on each thread
Then re oil!!
Then with a ratchet or bar NOT a gun😂 work the Beam nuts slowly off take your time!!
Like I said I done a few and never had a problem
Hope this helps
Ben perry
  Clio 172 cup
Then re oil!!
Hope this helps
