Odyssey blue ph1
Ben perry
Car  Clio 172 cup
So after mechanically restoring my dads flamer I really had the itch for a ph1.. and after bit of time the one piped up that was lurking online with overheating issues and on 200k miles but was was fair he was asking so had to have a look as wasn’t far from me and yer was impressed.
I thought I could break it and make money (how I look at stuff as worst case😂)and yer got it back to my unit
So plan was to pull the engine do cambelt water pump as I suspected overheating was due to pump not circulating and while I was there I’ll do clutch and all the bits that just make sense but!! Plans don’t go to plan once engine was out I was turning engine by hand and it was like having the plugs out!! 😂🥲 weird as it ran sweet disregarding the over heating issue so next was pull the head off see what’s going or gone down 🫣 and bores were really good for mileage as was the overall visual engine condition once head was off pulled valves and 14 out of the 16 were leaking like a siv..
So new plan picked up a 60k bottom end and a new set of valves and a victor rinze head set so should be sweet when done been picking up few little mods to on the way..
And yes the pump was ded 🤑🤑
Cheers for reading!!
Would love to have a unit like that! maybe one day!
Car looks in good condition externally! How are the arches? Definitely need to keep these ph1s going ;)
The car looks pretty clean, what's it like?
Cheers yer mate it’s a 10 footer doors and quarters let the car down but as far as rust go it’s really good!
Yer mate unit makes its nice 😅
As said it’s clean I’m gunner put a pair of quarters on it when weather warms up as that would mint it up
Cheers mate the colour is a winner for me and yer it’s pretty fucked but I don’t mind 😅 it’s a survivor!!
bit more done got pushed out side and fully washed the under side and engine bay with TFR all cleaned up really well next I’ll pull rear beam and tank of for powder coating and treating and under sealing..
few other bits fabricated cup panel and front subframe captives completed it m8
Hopefully should have my valves for engine tomoz 🤞
Little update got All my new valves lapped in nicely so head will now be going for a light skim leak testing and a good clean along with other engine parts..
Also cleaned the block right up with a needle gun treated and gave a lick of hammerd black looks nice tbf
Next I tripped all the back end down for treating underselling and powder coating
Nice and clean
Ready for the powdercoaters
That’s all folks 🥕
Unreal progress
i need to do the rear end of my ph1 once i get my 2 post lift installed
how did you remove the rear beam and keep the oem bolts in positon
previously i have always had a nightware when it came to removing the rear beam
Going like a boeing here pal, good on ya 👌 wish I had a 2 poster int garage, about skinned my back already. Ive got back end to drop off mine once the front is rolling and can turn it around! Any tips for a rookie 😂
Cheers mate I have been slack as I’m only just dropping bit off to powdercoaters 😅 although head is now been skimmed and tested just goto get all the engine bits cleaned 🥵
And as for the beam..
I have done a few and have been successful with every go!!
so firstly wire brush on a drill lots!! on the exposing threads
Next soak threads with oil I prefer to use engine oil in this case as it doesn't dry out
Next befor I attempt to undo the nuts I ran a thread chasing nut (m12x1.25) I think!!! Need to double check!! up the exposing thread to clean I do this couple of times on each thread
Then re oil!!
Then with a ratchet or bar NOT a gun😂 work the Beam nuts slowly off take your time!!
Like I said I done a few and never had a problem
Hope this helps
Then re oil!!
Hope this helps
Little update slow progress but works been manic 😅 I have got my engine all built up victor rinze head set with all new seals and genuine cambelt kit and dephaser looking good also got all my bits back from powdercoaters😍 think I’m gunner 2k paint front subframe just need to pull my finger out and treat and seal the car underneath now 🥲🤢
Finally an update!!
Been bit of time due to giving my vrs a light resto 🤢
But here we are so.. I stripped all the rusty areas underneath the car so inner sills rear spring areas areas ect I had to do some welding in the center part of drivers sill rear chassis rail and i had to repair front passenger jacking point.
The car has had outer sills in the past it’s not a bad job so didn’t really want to cut them off and I mean the cars done 200k so to me it’s not end of the world its overall condition is good and even the petrol flap area is original 🤯
Once it was welded and treated I give it a good hit withe some zinc primer and sealed it up with some pu sealer and ready for the unerseal
More to come cheers for reading 👍🏻
So next I got the shell under sealed look nice and fresh looking forward now to start putting it together
Then afterwards I had to do some paint on a customers car what happend to be a pretty close shade of blue and as the car is all ready a few shades i did the spoiler and petrol cap area
Eventually it’s getting a full respray to will be ok for now
I mean it look bad match on this pic but it’s the camera doing bit of a dirty 🫣😂
And I have also repaired one of the exhaust heat shields and as I was doing some wheels it would be rude not to give them a dusting of silver 2k I’m going to under seal the tops of them so should buy them a few more years
That’s all for now 👍🏻
Got some more done the other day got tank on cleaned up lines and got the Shields on, looks a bit tidier now
Then I moved onto giving the shocks a tidy up, it recently had a set of cup shocks but they had gone a little tatty so stripped them all down and good wire wheel and gave them a hit with some 2k black, who ever fitted these shocks re used seized bearing and maby a cracked spring😅
Got a load of bits into the powder coater so hopefully they’ll be done soon 🤞
Cheers for reading 👍
Got a bit more done last week got all the back half back together made cupra nickel (can’t remember what it’s called) and rebuilt calipers just waiting on my bits to come back from coaters should be any time now as I wanted to get front to rear lines on but I sent my flexi mount to be blasted and coated so that left to finish on rear
Also got front shocks built up with Debi bearing and purple rubbers and new cookspoorts
Engine in next I rekon 🥵
Cheers for reading 👍🏻
Some progress..
got the EPAS colum in fitted and wired up and while the dash was out gave it a good scrub and painted the silver bits with some 2k
Also got the cup spoiler on
So next back on the ramp got the old rack and subframe off ready for engine to go back in
Got the rear seal in the block as was the last thing to do then fitted a ttv fly and a new Luk clutch kit
Close to going in! maby get it in the car tomoz eve or Thursday see how work goes 😅 hopefully get all my powder coated bits back In the next day or two aswell
Cheers for reading
Cheers mate yes I noticed it’s stuck out slightly looking at my pic it looks flush it wasn’t tho😂 was a fucker to get in as was tin one 👍
So engine is finally back in!!! 🥳
Next I fitted up fresh subframe and dci rack and fresh gearbox end cover
Then it was time to lash the Zorst up I picked this system up for £50 including manifold so I fitted the cat and a new flexi not the best but I will make a exhaust in the future from scratch!!
Made a alternator bracket setup again not the best but it works it’s cost £25 🤷🏿‍♂️😅
NOS airfilter rent of engine/ bay back together
Also got front to rear brake lines on with new brake pipe mounting springs and also fitted rear roll bar
So yer here we are again couldn’t resist cranked it over with no plugs till we got oil pressure and had to try start it and surprise surprise the starter died not engaging 😂 exhaust manifold back off another starter fitted first rock of the engine it fired up straight away 😍nice and sweet just waiting now for some front wishbone bush inserts then we can get front suspension built up and go for a spin at last!!!
Ohh year and important stuff rear wiper delete !!!!
Cheers for looking!! 👍
update time.. finnaly got front end back together
Nice little drip tray
Got a cargo net a while back so lashed a bar to fit in and painted it to match handles and radio surround happy with that pointless little mod 😅
Oh and while I was clearing the boot out I found a Renault camera and a grayon
And here it was after driving out of the work shop need a polish and a good hoover
Got mot tomoz so will be on road then ready for a good fraaaaaashhh
More pics to follow of it being finished underneath and I filled all the subframe and rear beam of clear waxoil…
Mechanically I think I’m just gunner make an intake for it and make a full exhaust for it (even tho the car boot exhaust sounds good!!)
It will get a full respray at some point next year maby but here are some more pics
Now I can finnaly get on with this 🫣 might bang a tread up if it tickle anyone’s pickle?
But cheers for reading 🍻 👍
Good work! Nice to see another Oddy actually getting love, mines neglected from this perspective and just used
