The Dog Kennel
I've stuffed memory foam in mine it's far more comfortable now, but I'm still sat bolt upright like someone's Nan I her Honda Jazz.
Corbeau won't show up for a couple of weeks so Donny's going to be have to done in the ejector seat.
I'm going to bastardise a dumper sofa in the next few weeks. If I can find one with down back cushions that's the ideal. Might be more comfortable than the stock seats then 🤣
Bolt a wingback armchair in it, proper comfort.
Sod that, put an entire cottage living room in it.
A Cobra Monaco S I got off FB marketplace for £120, it's very basic with no padding and not at all comfortable, I've got some memory foam I can use for a cushion for now
That is quite literally, the seat I told you not to get 🤣
But, I’m glad I finally managed to steer you in the right direction.
If you complain about the Corbeau seat…
My complaints department is closed.
Permanently.
The Monaco "S" (for shite) is a lot comfier now I've lined it with memory foam, still sat bolt upright like a toddler in a high chair at a restaurant.
I gave you a subframe and sidemounts for a reason 🤷🏼‍♂️
It’s not my fault that somewhere in your special little mind, you went.. “a base mounted seat is exactly what I need!” 🤦‍♂️
Got enough ££ left over for some chiropractic treatment? Because my back is hurting from carrying you 🤣
Well now I'm keeping it and it's going on the passenger side, just so you can be as uncomfortable as possible.
