Darren S
Washed it - for the first time this year. It desperately needed it.
Thanks, it’s not perfect but for my first attempt at this sort of work it’s not too bad.That looks fantastic!
Definitely and the fact you have been badgering me for two years to sort it😂😂Looks good, definitely worth the time spent
Looks good. Proper multi-tasking too - looks like you managed to design the next BMW front grille at the same time...Finally sorted out my headliner after having the material for over two years.
View attachment 1779918View attachment 1779919View attachment 1779920
Keep us updated. I need to sort mine, move all over.Fitted some door mat clips as I was fed up with it sliding up under the pedals.
View attachment 1780451View attachment 1780452View attachment 1780453
If they work out ok on these I’ll look at cutting up my RS mats and get some added on there too.
I feel you, I took out my scooby from hibernation these days and now my Clio feels underwhelming. At least it sounds great above 5k and handles well so that makes up for it. I did wonder for a second when I took it out yesterday if something was wrong with it lolI've been enjoying driving the clio for a while now, they really are fun at not very high speeds and even more now that it's got a fruity exhaust note. But today I went out in the M2 and it's true, power does corrupt 😂. What a thing.
Looks much nicer!Melted 172 helm removed. Refurbished 197/200 wheel fitted.
View attachment 1782121View attachment 1782122
I have noticed a problem though which I may or may not have had before the swap. The steering column lock does not seem to operate and even with the key removed will not be engage.
Looks much nicer!
Tricky to do?
Cheers. It feels a million times better too.
Dead easy mate. I just followed this video. Even easier for me as I don’t have CC. The only thing that took a little bit of time was machining the spacer, luckily my dad has a lathe so we machined down a washer that I bought.
One to add to the endless list of 'wants'.....![]()
Much nicer than that Alien green one that appears every so often. Did you ask ChatGPT for a specific colour or just whatever its version of dark green is? If you can get that colour matched and wrapped (and can afford it) then f**king do it, it looks amazing 😍Asked ChatGPT earlier to colour my 182 in a dark green colour. Now I want it…. 😄
Literally asked it to colour it in a 'dark emerald green' and that was the result.Much nicer than that Alien green one that appears every so often. Did you ask ChatGPT for a specific colour or just whatever its version of dark green is? If you can get that colour matched and wrapped (and can afford it) then f**king do it, it looks amazing 😍
It looks fantastic!!! Sort of 172 exclusive scarab green!Literally asked it to colour it in a 'dark emerald green' and that was the result.![]()
Is this compatible with the regular f4r? Did my oil today and this made a bit of a mess.Oil change using the 3d printed oil filter thing which stops it pissing over all the pipes on the Megane.
