Darren S
Washed it - for the first time this year. It desperately needed it.
Matt Cup
  Iceberg 172 Cup
Fitted some door mat clips as I was fed up with it sliding up under the pedals.
If they work out ok on these I’ll look at cutting up my RS mats and get some added on there too.
helpimonfire
  '06 197
Not today because I haven't long crawled out of bed but yesterday I gave the little TCe Clio a service and finished fitting the parts cannon delivery to the front suspension to make sure it doesn't keep knocking like a t**t. Great success! Drives really well now so I may just keep it.
The engine oil was desperately needed though, the stuff that came out was a bit gloopy so I'm going to run it for a bit then change again, just in case.
Clio_fool
I've been enjoying driving the clio for a while now, they really are fun at not very high speeds and even more now that it's got a fruity exhaust note. But today I went out in the M2 and it's true, power does corrupt 😂. What a thing.
Brigsy
  T.Turbo
The r26 that i fitted ecumaster black to a few weeks ago was in at Efi for mapping on Wed. Went down incase of issues, all went well. Had to stop at 24psi as r26 oem throttle body was getting flappy at high rpm, needs an upgrade..
Swichable maps done. 350hp/300ft lb on 14psi/low boost. High boost 24psi at top 430hp/360ft lb.
Feels like a totally different car now Chris has mapped it. Smooth and traction is pretty good compared to the last map on stock ecu from elsewhere which was like on/off switch.
Need to get a throttle upgrade sorted and dial in boost by gear on the street, as ecumaster was reporting 159kmh with abs fault due to rear wheels not turning on dyno. Bit of head scratching on that one initially, but its simple to sort on the street.
mumpy
  Clio 172, WRX STI
I feel you, I took out my scooby from hibernation these days and now my Clio feels underwhelming. At least it sounds great above 5k and handles well so that makes up for it. I did wonder for a second when I took it out yesterday if something was wrong with it lol
EoinS
  Clio 200 Cup FF
Refitted the second set of wheels and dropped the car off the ramp to get it cleaned and it wouldn't start - cranking but not firing. I thought it might be to do with the battery having been disconnected, although it had already started more than once since then. Did a power-down reboot and it was still the same. Removed and checked the crank sensor - dirty and rusty, but probably more importantly, the nib for the clip has been mangled, so the plug doesn't click home properly. Cleaned it up and filed the rust off the sensor tip and it fired up straight away. New sensor ordered from RPD.
Mr Squashie
CSF Harvester
  Clio 182
Stuck my proper wheels and tyres back on now that it's not snowing any more. I think I'm going to try and find some different wheels for next winter because the sight of those kerbed and badly painted 182 wheels fills me with disgust and shame in equal measure.
Changed my power steering sensor, fingers crossed that's actually where it was leaking from. If I don't hear the pump whining in the next 6-8 weeks I'll assume it worked.
And as a bonus I think I've fixed my centre cap which randomly decided to fall out, but I'll have to wait until tomorrow to check.
Matt Cup
  Iceberg 172 Cup
Melted 172 helm removed. Refurbished 197/200 wheel fitted.
I have noticed a problem though which I may or may not have had before the swap. The steering column lock does not seem to operate and even with the key removed will not be engage.
Matt Cup
  Iceberg 172 Cup
RS insert fitted.
Didn’t come without any injuries though 😢
Renault in their wisdom just left the fixing screw loose in the bag so the fascia took a bit of a hit.
Matt Cup
  Iceberg 172 Cup
Looks much nicer!
Tricky to do?
Cheers. It feels a million times better too.
Dead easy mate. I just followed this video. Even easier for me as I don’t have CC. The only thing that took a little bit of time was machining the spacer, luckily my dad has a lathe so we machined down a washer that I bought.
Darren S
One to add to the endless list of 'wants'..... :p
Matt Cup
  Iceberg 172 Cup
It’s a worthwhile mod imo, I never really liked how it felt to drive with the original wheel.
Plus this wheel came up a hell of a lot cheaper than a refurb so I jumped at the opportunity to buy it.
Matt Cup
  Iceberg 172 Cup
Yeah I could do but getting the airbag off is a pita and I’m not sure I can be arsed messing now, also not sure how it would affect the locking pawl as that whole mech is well behind the squib and other bits and bobs on the column.
helpimonfire
  '06 197
Finally got around to stripping the dash and dash bar out, heater out and got the front half of my cage in and ready for the feet to be welded in. Bit of a faff and the next time I put a full cage in a car, I'll be paying someone else to do it!
Mr Squashie
CSF Harvester
  Clio 182
Asked ChatGPT earlier to colour my 182 in a dark green colour. Now I want it…. 😄
Much nicer than that Alien green one that appears every so often. Did you ask ChatGPT for a specific colour or just whatever its version of dark green is? If you can get that colour matched and wrapped (and can afford it) then f**king do it, it looks amazing 😍
Darren S
Literally asked it to colour it in a 'dark emerald green' and that was the result. :)
EoinS
  Clio 200 Cup FF
Adjusted the rear suspension height after fitting the missing top spring rubber mounts. With the front raised a little bit as well, I can now drive on the local roads without rubbing. Refitted the wheels onto the stud conversion done yesterday - much easier now. Repaired a loose exhaust heat shield that was rattling. 2 weeks to the first TD in the Clio.
helpimonfire
  '06 197
Finally got around to starting to fit my Pierre Gasly Golds. OSF went fine, no issues there. NSF has fought me the entire time. I've got the rears to do shortly and I'm expecting that to be a fight too.
Clio_fool
Fixes the clunk, again. Took it for a quick spin upto town and over the speed bumps and all good. Got home and the fucker won't lock or e cognise the key card unless it's in the dash slot. New battery, same s**t so looks like I'm doing a dance about to lock the c**t until I can get it sorted. f**k clio's.
