clio MK 2 d4f 728/ 784 frankenstein
Car  Clio 2
i have a few questions about the diff, transmission and the drive shaft.
1. is there a a lsd slip dif that fits in the original transmision to make it drive a bit better so less 1 wheels spins if so what do i need and second is it easyer to get a later gen transmision from a gen 4 or 5 clio that has a 6 speed and put the shaft with some outer shell modifications into this trans because i want to go from a 5 speed to 6 driving at 3250 rpm is not that great if you drive 100km per hour
2. does the driveshafts from a 172 fit into the trnasmison from a 1.2 16 v d4f 728 ifso great then i dont have to take it appart to check it
3. why do i do this eeh the head was a astraight fit it handles boost ok and the gears are not orignal if anyone wonders i just need to know if some things are a straight fit because thats easyer then making it yourself
sorry for my bad english in advance
information about the car that i have
clio 2 mk3 d4f 728 with machined pistons connecting rods and crankshaft
784 head
aftermarket turbo went first with the orginal 784 turbo but is to low on boost to pickup at higher rpms
redline 7250 orginal 6500
radiator is from a aftermarket 172/182 for better cooling
ofcourse a few bits and bobs for the oil cooling and for the turbo ofcourse
suspension bilstein b14's
rear beam stil orginal drums disks / beam swap from a cup wil be going under this in the upcoming summer
downpipe is home made to fit to the orginal 182 cat and exhaust from the 172
injectors are from a f4rt not from the clio 2 172/182 because of spare parts laying around
(a lot has been grabbed for s***s and gigs and what we had laying around just to see what the engine can take
currently it ar 212 hp and 308 nm of torque
front brakes brembo drilled rotors vented 260mm need to go to the 2 pods from the megane 2 rs 300 mm
they get to hot
Nordschleife is being used for testing and racing thats why wil be done with the rear beam at the same time with a other parts from a clio rs and megane 2 rs
brake pads front ferodo racing parnt nr FDS845 if you want to know the specific one
diffrent cam was first from the 784 but now a road cam i think thats what its called in english XD
has it worked ok til now yes will it blow up maybe probably
has it survived 63000 km yes 39100 ish miles
so you can hate it or love it
i just want to learn XD
why?
saxo people and a lot that i have read was buy a 182 i have one and i had time on my hands for this one to mod did it cost a lot no again old parts mainly from cars that where ment to go to the scrapper so it has probably parts from over 30 cars at this point
if anyone can help to get this nugget further thank you in advance
if you say you wasted your money maybe maybe not it was only 2800 euro's and the car was 0
a rs over here is 12 a 13000 euro's so maybe i can build a list of what i can be done for upgrades for a other 1.2 user
🙌ofcourse not a just beginner driver XD they need to learn how to drive first
Welcome to ClioSport - Cool project, more pictures and videos required!!
Still running JB1 box? they look similar casing wise to a JC5 (172/182/dci 80)so maybe a JC5 diff would fit but im not sure. (starter motor is at the front on a JB1 and rear on a JC5) - A diesel JC5 box would have longer gearings but i believe a few of the 172 turbo guys say they are not well suited to a 172 tubro unless running 300hp+
the 6 speed boxes are massive and would require quite a bit of work and possibly chassis leg modification to fit.
Should do, people used to fit widetrack to a 1.2 16v from a 172 using lower arms/arb/bigger brakes/hubs and id assume shafts! - There will be info on here from 20yrs ago with a search.
Your English is better than most English people online these days!
If you can get a rear beam from a 2004> 1.6 16v or DCi100 then you will have no issues with ABS, you will if using a 2.0 16v beam.
they get to hot
Wide track conversion as mentioned above using 280mm 172 setup will help with that!
thank you the help and sorry for the late reply i was out of the country for a bit
its indeed the jb1 i tryed something on a extra box but with a bit of modification you can fit the 6 speed internals from a later d4ft into this one but indeed you kinda have to change the outside of the box but it works perfect
awesome it does fit fortunatly havent changed it yet have to gather a few more things to do that part then the box will go in the car to
thank you very mutch ^^
awesome i will look into that more i got the callipers and everything from the rs but we should be getting next week a 1.6 here in the yard
they get to hot
thank you again for all the information you have helped out a lot i can't thank you enough
