Rear discs are mintexThe rear beam does look lovely freshly powdercoated
What make are those rear discs?
Yea the mains bits went back to bare metal rust converter and then buzzweld productsLovely work, did you bare metal the underside?
Yea at first I thought that but I was surprised that the chassis was pretty good condition.I saw the second pic and thought “he’s not saving this, that’s finished!”
Wow!!! Hat’s off to you mate, that’s amazing.
Wow. Great work.
What nuts/bolts did you used to reattached the rear beam brackets to the car? The ones that go through the body.
I see you used SSL Horbury to do your calipers - I've had a few set's done now and I'm always over the moon with the results, and especially for the price they charge.
Took this picture a couple of weeks ago however I had them done over 3yrs ago now and they still look like new.
Epic epic restoration fair play. Just umming and ahhing whether to do a full on mine. It's nice and clean but inevitably hiding some gremlins underneath.
Do you have a cost ceiling in mind? On accounts of you doing it yourself that obviously helps but I'd be interested to see if you have a target price in mind?
Waaaaaay cheaper that my rear quarter fixes!worth doing for sure specially if your going to keep the car for a long time
This what I spent on most the parts/work
Calliper refurb front and rear £265
Primer £99.21
Rust converter £12
Sealant £28.26
Under-seal £361
Powder coating £200
Bolts £150 rear axel, rear damper, fuel tank and axel to chassis
Stub axel bolts £38.67
Axel bushes power flex £115
After Market Handbrake cable left right £45
Abs sensor £39
Discs pads £130
Exhaust hangers £79.95
Exhaust hanger mounts £65
BRT rear braided hose £75
Rear exhaust bush £14
You can get all the bolts cleaned and plated if they are not to badly pitted, I was £20 for all mine to get done from a local industrial coatings firm. The front subframes are galvanised from factory so that would come up good with a good power wash/strong cleaner.update
Interior nearly pretty much done, Been waiting for my steering wheel/boss to arrive that I brought back in November from K-tec
subframe been sent for powder coating, got the driveshafts and steering rack to send off for refurb.
Next up take the engine out and start refurbing the arches etc
Pretty much need/want to replace all
Bolt’s does anyone know the best place to get replacement??
Powder coating anything on the underside is fine if you dont plan to run the car through the winter months, if you do then avoid at all costs as it just falls apart after a few years due to stonechips, thats my experience anyway, I'll never powdercoat anything underside of a car again.
Where did you get your seatbelts done?haven’t done much lately put new head liner in and new seat belts, got steering wheel on the way. Just waiting for the interior parts to come back from paint.
View attachment 1770989View attachment 1770990View attachment 1770991View attachment 1770992
Going to start on front end next, taking the engine out might send off to engine dynamics to be rebuilt will change engine mounts, updated rad etc but anyone recommend me doing anything else that’s a must?
View attachment 1770994View attachment 1770996I’m
www.kolourkoncept.co.uk
Thanks @NickReilly063, yours looking good where did you get the bolts from? I got new ones for the rear but they wasn’t cheap direct from renault.
@NickReilly063 After seeing that I’m going have to take the hit on them, going try get the zinc plated.
