White plug (under fuse box) pin out
Ben perry
Car  Clio 172 cup
As title anybody got a pin out for the white plug would be handy for when wiring k20 up
Cheers again Ben
Bit of a thread revival here as Im after the same for both phase 1 & phase 2
Yeah i've got the same as what Jon mentioned.
R67 is the connection.
You'll find all the info on that link.
Hi. The link in this thread to the pin layout isn't working anymore. I have been reading in the X65 wiring diagrams but can't find the pin layout for this plug. Anyone have it?
Thanks. Was the wiring to the connector. Fault code P0638 showed up in generic fault code reader, but with Pyren I found fault code on "Pedal potentiometer track 2" simultaneously.
Track 2 Pedal is pin D 4,5,6 on the connector. Traced the wires and found two cuts.
Fixed.
