TheBandit
What's the belt size?
I'm sure I slackened the tensioner and moved it forwards to alleviate the rubbing before. But then I also saw there was a dodgy shite set of tensioners as well cos there was someone on Facebook with the issue
It's just easier to f**k the lot off and run the full PMS kit![]()
Fair enough, SKF kit is 1660 for reference if it's any use in future
I didn't use a pulley delete kit but went for Lambert's style while maintaining the small bottom idler pulley
Not that it helps you right now... but it's an option
You know what, that does help.
I didn’t realise that kit was as cheap so f**k it, I’ll order one of those and I’ll sack all the crap off with the tensioner. I’ll sell the PMS PAS delete pulley on once it’s done too.
What belt did you use if you kept the bottom pulley?
