Clio 182 Turbo
I'm sure I slackened the tensioner and moved it forwards to alleviate the rubbing before. But then I also saw there was a dodgy shite set of tensioners as well cos there was someone on Facebook with the issue
It's just easier to f**k the lot off and run the full PMS kit🤣
What's the belt size?
Not sure tbh. It was a genuine kit so just whatever it came with. Although it’s pretty much fully compressed with the belt on.
I might do that. Or even try a slightly longer belt. I wonder if my alternator isn’t quite right and just holding the belt a bit too tight.
The first tensioner that came with the kit was absolute shite. The casting was terrible and it snapped at the first sign of any pressure to turn it. This one is better quality, despite having the exact same markings, but it’s just pissed.
I’ve bought enough s**t now, they’ll be no PMS kit 😂
Fair enough, SKF kit is 1660 for reference if it's any use in future
I didn't use a pulley delete kit but went for Lambert's style while maintaining the small bottom idler pulley
Not that it helps you right now... but it's an option
You know what, that does help.
I didn’t realise that kit was as cheap so f**k it, I’ll order one of those and I’ll sack all the crap off with the tensioner. I’ll sell the PMS PAS delete pulley on once it’s done too.
What belt did you use if you kept the bottom pulley?
If you order from him I believe it includes the belt for the setup pictured.
To retain the bottom idler I used Dayco 202779325 (5PK1212). I did have to remove the idler, fit the belt, then refit the idler as I couldn't get enough stretch
I built my kit so big disclaimer: that size may not work with his kit of you do order it. I can DM you the bits I bought if you go DIY, don't want to step on any toes.
Stuff turned up today. Got a clutch. Didn’t want a padel but that’s what I’ve decided to go with. Should be ok converted to hydraulic. Got some new flywheel bolts too.
Turinis turned up too. Photos did them a lot of justice. They’ve definitely been painted by a blind man. However, they are straight so will come up nicely with a refurb so will get them dropped off over the next few weeks.
All the clamps are now swapped for the hi-grip ones too. They are so much better than the old ones so thanks for the recommendation on that 👍
There are days during a build where genius and pikey must clash in equal measure. Today was that day. I need the engine off the stand and had an offer of a crane. However, given I move at glacial pace, I didn’t want to take a stand up forever.
So instead, I’ve dangled it off the roof. Proper legit 👍
Flywheel on and torqued
Fitted the clutch, aligned with a 12mm impact socket as alignment tool which is a perfect fit. No pics. Then got the box on. Currently held on with. Couple of random bolts cos no idea where I’ve put the actual bolts. They’ll be in there somewhere. Nice to see it back in this shape.
The new aux setup as suggested by @TheBandit arrived yesterday so went on today.
I really should have just done this the first time round when I sacked the PAS off but never thought of it. The only issue is that I’ve got no idea how tight the belt should be. When I twang it, it’s probably at about a D. So if anyone could twang their belt and decide what guitar string it corresponds to it would be great. But in seriousness, I’ll just fire it up and if it squeaks I can add a bit more tension.
No sign of my PMS hydraulic clutch conversion thing and still can’t find the box bolts so pretty much stuck for things to do for now.
When i twanged mine it used to sound like this
Clio 182 Auxillary belt tension
Aye you will need to use the app above or a seem gauge to check tension.
Dci setting instructions above to give a rough idea. Measure frequency on longest length. From experience you will be tighter than you expect to get the correct frequency.
New belt set up looks loads better.
Gates do an app where you can pluck a belt and it tells you the frequency, I had to use it when doing the timing belts on my Ducati
https://www.gates.com/us/en/knowledge-center/calculators/belt-tension-calculator.html
Has got ball park figures for multi V aux belts too
Aye you will need to use the app above or a seem gauge to check tension.View attachment 1805776View attachment 1805777
Appreciate that gents. That’ll take some of the guess work out. I’ll give that a crack during the week and see if I can get it near the DCi settings above. Thanks 👍
I like this game. Had to grab a new pack of beers out the garage so gave it a twang. You weren’t wrong about being tighter than expected @Brigsy , that’s pretty much as tight as it’ll go with all threads used. Bang on though 👌
